Tip & How-To about Microsoft Mlf Visual Studio Enterprise Edition 6.0 (628-01289) for PC
Avoiding the Beep
When you're entering information into a text box and press , you'll hear a beep. You can easily avoid this behavior. To do so, place a text box on your form (Text1). Enter the following code in the KeyPress event:
Private Sub Text1_KeyPress(KeyAscii As Integer)
If KeyAscii = 13 Then
KeyAscii = 0
End If
End Sub
Microsoft Mlf Visual Studio Enterprise Edition 6.0 (628-01289) for PC Logo
car radio phillips 4 digit code
if it came in the car look in glove box for code or in owners manual or go to the dealership......from phillis you will need to contact the company with the SS# and model.# sometime it is in the book that came with the radio
Jun 04, 2012 | Renault Clio Cars & Trucks
2010 mahindra scorpio: how do you program a 2nd alarm remote
You'll need to find the valet switch in your scorpio. It is in glove box, towards the top, near the metal clip in which the lid of Glove Box Locks. You have to turn "ON" the ignition. Press that button once.....Leave it Press that button again and hold it You'll hear a beep confirming remote programming mode Now press lock button of each remote to be programmed one by one for atleast 2 seconds You'll hear a small beep on each button press confirming successful remote registration Now leave that button and close all doors and check the remotes for programming
Mar 11, 2012 | 2011 Mahindra Scorpio
How do I install my Win XP whn I have changed my harddisk ?
plz follow the steps...
1. Insert windows xp bootable cd into the drive
2. Power on the machine
3. When the logo displays, press F12 to show the boot menu
4. Select the CD/DVD
5. System will start the job
6. After showing Setup is starting windows, it'll shows the install option
7. Press ENTER
8. It'll show the drive but the drive is not partitioned
9. You can easily understand by reading the instructions
10. While creating it'll ask for drive space
11. Put 50000
12. Press ENTER
13. It'll ask for type of file system that you have needed, select the 1st one (Quick using NTFS)
14. It'll ask 4 format the specific drive. for that you have to press 'F'
15. It'll format and copy the needed files
16. System will restart. After restarting it'll start the job. plz wait.....!!! (system restart many times to complete its job)
17. While working it'll ask for the product key, time, etc.
18. Sit infront relax and give the needed information that you can understand easily
thanks & regards
Anas K A
May 28, 2011 | Fujitsu Lifebook T1010 Tablet PC
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
beeping when i turn on and black screen
IT is either one of three things.
  1. keyboard missing; check it's plugged in.
  2. graphics card; check that it has not been dislodged and is seated properly.
  3. memory. Are the memory cards properly seated?
Apr 02, 2009 | Dell OptiPlex 170L PC Desktop
1,254 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
