Tip & How-To about Photography
Organize negatives for easy access
Over the years I have accumulated an astounding number of pictures and rolls of negatives. They were scattered all over the house in numerous boxes and albums that it started to get out of hand. A few weeks ago I decided to organize my collection of memories into something more together than scattered boxes. I have found that sorting developed pictures was really easy because you just put them all in albums and the problem of organization is solved, negatives on the other hand are a little more complicated.
Like developed pictures you have to protect your negatives from water, but they are also sensitive to dust and hands touching them. Since they can get easily scratched up you have to store them somewhere they won't get played with. You also have to keep them flat because if they get rolled up or folded they will be hard to use or even impossible to make more prints of the images on them.
What you want to do is get some clear plastic negative sleeves. A sleeve can hold an entire roll of 24 exposures so you can store a whole roll together. If you were some what organized before we started you should have information about the rolls of film like when they were taken and where. Using a pen or a sharpie you can lable the negatives for easy access.
Then all you need is a 3 ring binder to store all your negative sleeves in. If you want to get reallly organized you can even create a system of organization for your ablums so you can label the sleeves with the album information so you can easily find the corsponding prints.
The time that is takes to organize your library of photos depends on how many you have to begin with and how organized you were to begin with. I have been working on this for two weeks now and am almost finished!
Photography Logo
where there is anything in picture that is white in colour, the white area is filled with a scattered pink colour-
could be 1 of two things - tcon board or av board. I'd check th etcon board first though. I just replaced a tcon board that caused the screen to look like a picture negative.
Thanks,
Michael
Apr 05, 2011 | Hitachi 26LD6600 26 in. HD-Ready LCD...
How do I change a blower motor in a chrysler Town and country
Hello, to change the blower motor resistor follow this steps:
  1. Disconnect and isolate the battery negative cable.
  2. Open the glove box.
  3. Flex both sides of the glove box bin inward near the top far enough for the rubber glove box stop bumpers to clear the sides of the glove box opening, then roll the glove box downward.
  4. Reach through the glove box opening to access and disconnect the instrument panel wire harness connector for the blower motor resistor from the resistor connector receptacle.Blower motor Resistor
  5. Reach through the glove box opening to access and disconnect the blower motor pigtail wire connector from the resistor connector receptacle.
  6. Remove the two screws that secure the blower motor resistor to the evaporator housing.
  7. Remove the blower motor resistor from the evaporator housing.
Thanks
Aug 25, 2010 | 2006 Chrysler Town & Country
Canon EOS Rebel S taking bad pictures
Your camera has a faulty shutter or shutter timer.
Given that you can buy a perfectly good Rebel S for anywhere between £1 to £25 on Ebay it's not economical to repair it.
Jul 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
pictures did not take-negatives were clear
It seems like a fault with the shuttter.  You will need to get it repaired.
Dec 12, 2008 | Minolta Maxxum 7000 35mm SLR Camera
HOOVER U9125 990Z VACUUM CLEANER
Sounds like either the hose or the inlet down where the brush roll is is clogged. Either that or you have a motor fan problem. But this has a years warranty on it, so find out who in your area does Hoover Warranty and take it in for repair.
Nov 04, 2007 | Vacuums
735 people viewed this tip
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
