Home | All Products | E173FP 17" LCD Monitor | Tips
Monitor led is blinking or steady, but the display does not come up
ginko
By Guru ginko
Rank: Guru
Rating: 89%, 5021 votes
posted on Apr 22, 2009
Helpful
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Was this helpful?
Yes
No
43 people thought this was helpful
Comment #1
posted on Nov 17, 2009
radioctrldwi
By Apprentice radioctrldwi
Rank: Apprentice
Rating: 0%, 0 votes
Can anyone point me towards a free service manual for this monitor?
Comment #2
posted on Sep 16, 2009
mnow
By Apprentice mnow
Rank: Apprentice
Rating: 0%, 0 votes
C10 - 11 on my board are definately not 820uf
they might be as big as .1uf though
Comment #3
cryptograph
By Apprentice cryptograph
Rank: Apprentice
Rating: 0%, 0 votes
C10/C11 on the inverter board: are those the SMD capacitors on the board under the small metal housing, or are they on a different board/do you have pics?
Comment #4
posted on Sep 11, 2009
rdriscoll
By Apprentice rdriscoll
Rank: Apprentice
Rating: 0%, 0 votes
I have fixed 6 of these so far. All you have to do is replace capacitors C10 and C11 on the inverter board. They are 820uF 25v. The stock CAPXON capacitors are known to be bad.
It cost me $2 per monitor.
Can you Help with these Monitors problems?
Dell E173FP 17" LCD Monitor
ghosting on everything on the screen. Everything looks...
How to connect, out 6 pins S-video to TV scart ?
E173FP 17" LCD Monitor when turned on goes as far as...
have dual monitors, but when moving stuff from primary to...
dell AS500 screen cut off before login
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
