Tip & How-To about Televison & Video
Dedicated micro digital sprite 2 (no cd rom type) cctv recorder.System freeze
System freezes after a few hours being turned on. There can be a number of faults that will cause this 1 and 2 is the hard drives master driver or slave. 3 is the power pack (PSU) these can over heat and burn out the capacitors and fan these will need changing. then there 4 there is 2 fans in the unit these can fail or slow down making the unit overheat these fans are 5v 40mm bearing type. you can change these for 12v same size and run them off the hard drive wiring.the system should never go over 40c new hard drives can heat up to over this and cause the unit to over heat so you will need to put cooling fans on the bottom of the hard drives and make a barrier between the hard drives and mother board i have done this with some card board and left a part open were the fans are fitted. this has worked very well hard drive area temp was up to 50c and mother board was at a steady 30c with room temp at 29c. now for number 5, there are 2 chips on the left side of the mother board just pushed in. these can lose contact, you will need to remove them and clean the pins on the chips just prise them out carefully and clean the pins even a bit of silver conduct will help used for repairing damaged boards. let it dry then put the chips back in, making sure they go back in the same way they came out.the are the memory chips newer models don't have these, they have memory like a pc/laptop. but they can do the the same thing. Its is best to do a full rest if you are not changing hard drives, wipe both the hard drives on a pc. reformat them to FAT32 and down load the firmware from dedicated micro.remember the firmware is the same as the one that was on before, to find this out in the first menu it will tell you the boot firmware and system firmware ie 3.1 etc. the hard drives now formated on the main drive (master) place the files from the zip file from the down load onto the hard drive slave drive as long as it is formated that is it the system does the rest to it on setup. shut down the pc or what ever you are using and remove the hard drive and reinstall it to the digital sprite. when every thing is back together it is now ready to be setup. plug all the cameras back in and what ever you have to plug into it. don't have the power on to the cameras wile doing this. turn on the power to the digital sprite 2 now it will setup and unzip the files to the drive. then turn on the power to the cameras. when finished it will still be setting up . banner should be on screen the screen fixing files to c drive then d drive them image file to d drive after this is all done go to menu on first menu check numbers of the unit. the go down to shut down and shut down unit. press 1 when asked to for 5 seconds. now leave the unit of for 10min. then turn back on. and this is how to fix a faulty system you will now need to set up system to how you want it most setting will be the same but some will have been lost like . internet setting and camera setting colour and external keyboard control setting they will need to be rest. but wiping the system and reinstalling it will help as every time the system freezes it can loes files or images. hope this helps as meany as it can with a freesing systerm.
Televison & Video Logo
my laptop freezes on start up most times.I've had it looked at and they say its my motherboard.Its 13 months old.could you advise.ADVENT 5431
to prove a point 1 is it over heating and does the fan spin. 2 turn on and enter the bios should show time and date leave there for a few hours if doesnt freeze the chances are its not over heating, poss hard drive or memory i would have a guess hard drive bad sectors but dont hold me to that!
Feb 11, 2010 | Computers & Internet
operating system not found
Causes :
  • Hard drive is not detected on the system
  • Hard Drive starting to fail / Damaged
  • Incorrect Master Boot Record (MBR)
There are a number of solutions that you can try on. Here is a link from Microsoft that will give you all the steps to verify the root of the problem. Click on the link :
http://support.microsoft.com/kb/321626
--------or---------
Operating system not found causes / Solutions
Nov 03, 2008 | HP Compaq Presario SR1420nx...
Windows won't load or instal
Freezing of computers occur mostly due to shortage of RAM. But in ur case, 1GB is quite enough for XP. Since ur computer is freezing b4 even starting up, thus it could be a problem of disk drives.check if more than 1 drive have been alloted MASTER (Primary) or otherwise same priority. If u have more than 1 HDD, then the one in which the Opering System is installed should be given the Master Primary and the other as Cable select/slave. Likewise do it for the CD/DVD ROM or RAM (the CD/DVD RAM should be alloted the master and ROM as the slave). It can be done by the JUMPERs on the back of the Drives. See the exact setup on the drive surface.
Oct 09, 2008 | MSI K9MM-V Motherboard
I left my ps3 on all night with a movie on pause, and now I can't get it to do anything. I took the movie out and shut the system off for a while and every time i turn it back on the screen is black. what should I do?
I the hard drive might have overheated if you didn't have your system near a fan or source of cool air. Try unplugging the unit for a few hours and let it do a self master reset, and then turning on the unit and see if the hard drive reboots.
Jul 23, 2008 | Video Game Consoles & Games
E602 0001 - ir8500 Canon
Turn machine on while honding down the 1 and 9 keys.Machine will run a hardrive check program that takes 20-30 min.Power cyle main power in about an hour.If this dosn`t work system software and or new hardrive.$$$$$
Sep 17, 2007 | Canon imageRUNNER 8500 Copier
780 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
