Tip & How-To about Home
How to properly clean and care for your airpot
To clean your airpot you have to first make sure that it is turned off and unplugged. Pour out the water that is still in the airpot if there is some and allow it to cool down. Once it has cooled down you can begin to clean it.
You want to start with a since of the inner lining using hot water. Use a sponge to get loose debris off the lining and rinse again.
Fill the pot up again with hot water and few drops of mild dish soap, let this solution sit for 10-15 minutes. Using your sponge again scrub the inside of the pot then make sure to rinse both the sponge and the inside of the pot to get all the soap out.
If there are any mineral deposits in the pot you should fill it with hot water and about 2 Tbsp of white vinegar. Let it soak for about an hour an then rinse thoroughly you don't want the taste of vinegar in your water.
To clean the spout you pour some of the water and vinegar solution out the spout then rinse with fresh hot water.
Finally to clean the outside use a damp cloth to wipe it down and a dry one to wipe it dry. in the case that you have stains on the outside use a mild dish soap to clean, rinse with clean cloth and then use a dry one to wipe dry.
Home Logo
swan steam iron 2200w
To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the lime scale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any residual vinegar etc. Turn off and unplug the iron and pour out the remaining water. Descale completed.
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Nov 30, 2013 | Irons
how do I descale my iron
Oct 29, 2013 | Irons
brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
how do you turn on the classic coffee concepts airpot?
As far as I can tell ( I do not have a maunal that is why I am here) there is no on and off switch. It stays on untill you un plug it... It boils then goes in to Keep Warm mode untill you either hit Reboil or unplug the unit from the back or the wall..Hope this helps!!
Jan 08, 2011 | Classic Coffee Concepts Airpot Style Hot...
can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Jul 20, 2009 | Coffee Makers & Espresso Machines
999 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
