Tip & How-To about Photography
Step by step guide for rolling a film reel for developing
Rolling film on a metal reel can be very challenging and for years I avoided using these reels in favor of the plastic ones with the large lip for leading the negative around the reel. Over the last year or so I have been working on getting around this fear of not being able to roll the film.
The first and most important thing that you have to make sure is that when you cut off the "L" shaped piece make sure that you cut the film between the sprocket holes. Those first few holes are crucial for the ability to successfully loading the film on to the reel.
On the center post of the reel there are two very small hooks that you want the negative to hook on to using those sprocket holes. These hooks work to make sure that the film stays put while you roll and throughout the development process.
Once the film is hooked on you are going to slowly turn the reel around and around holding the unrolled film on the sides. Make sure to hold on the sides because you don't want your fingers to scratch the very sensitive negative.
If you practice in the light with dead rolls of film you can check if you rolled well by holding up the roll and looking though. If you can see between the rounds of film then you have done a good job. It is important that the film be rolled smoothly because if parts are touching then the chemicals can't get in and the film will not develop properly. Once you have mastered rolling this way in the light take some time to roll a dead roll of film in the dark before you get to the real stuff (no pun intended).
Photography Logo
film stuck in on right hand side
First, be sure you've pushed the film release button (usually located on the bottom of older film cameras) and then try rewinding. If the film is stuck on the take-up reel of your camera your best bet is to manually unwind the film from the reel and see if it will work properly again. If not then it wasn't a film problem but a mechanical one on the reel.
Feb 15, 2014 | Canon Photography
re-align the film roll on the Drum. This worked for me. There are two wheels on the outer-side of the film reel (the film reel is one of two reels on the main top drum). Take out the drum, not the green reel, but the other one. Check both ends and you can se/feel two little silver metal wheels (again, at the ends). Roll the film around with your fingers until it is aligned evenly with the wheels. The metal on the wheels should not be showing at all, they should both be covered by the film reel. Replace the drum
Jan 31, 2011 | Dell 3000cn Laser Printer
film is not winding on fully
Possible that the loading motor is having friction to load fully or that the film reel is too tight.
You can check the test without the film in place but by activation of the door switch.
If the reel pressure is good ,then the film reel might be badd or if the hand pressure stops the reel then the motor might be weak.
Hope the battery is charged. if not used recently let it run winding up to free.
Sep 19, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Bell+Howell FILMO 8mm Projector
Hello
Thank you for using FixYa for your problem
sounds like the takeup belt is wrong or the speed motor
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Bell & Howell Photography
BLANK REELS AND A MANUAL FOR THE RCA REEL MEDIA CENTER?
You can find the manual here: http://web.archive.org/web/20050111070512/http://www.avs.ca/uploaded_files/owner_manuals/841558_reel_media_center_ib.pdf
As for the reels, there are 2 possible solutions:
1: Try to find new old stock reels. The website for Polyconcept
USA (which made the Reel media center) has been down since 2008, so the company may have gone bankrupt.
I found one internet shop that may still have blank reels for sale: www.americanbargain.com/product.asp?productid=7008
2: You can use 1/8" Nagra reels which are still being made, the tape is the same 1/8"(3.175mm) width as the tape used on the Reel Media Center.
The Nagra reels have a different hub, so you will need to improvise and make your own hub adapter.
I found reels like that on Ebay: http://cgi.ebay.com/NAGRA-SN-METAL-REELS-for-SN-SNN-SNS-SNST-10-REELS_W0QQitemZ400026885481QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item400026885481&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Dec 07, 2008 | RCA BLANK REELS FOR THE REEL MEDIA CENTER...
983 people viewed this tip
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
