Tip & How-To about Akai PDP-4249G 42 in. EDTV-Ready Plasma Television
RESET ALL CODES AND PRESETS
IF YOU GET LOCKED OUT OF YOUR TV OR ITS MENUS IN ANY WAY USE THE REMOTE AND 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THE SCREEN WILL FLIP BLACK FOR A SECOND AND THEN HIT MENU A FEW TIMES TO BACK OUT OF THAT TASK. THIS IS THE UNIVERSAL V-CHIP FOR THIS TV AND MANY OTHER RESETS.
Akai PDP-4249G 42 in. EDTV-Ready Plasma Television Logo
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Hi I have a AKAI 42" widescreen Plasma HDTV monitor "TV" PDP4225M I have been trying to contact the company to get help but know one is around.. ok my problem is 2 years ago we put in a pass work to block R rated pg...ext and now we forgot the pass word to unblock ....please HELP... Rick...
Please try this answer from another FIXYA asker:
http://www.fixya.com/support/t183286-v_chip
Credit this to mikeandtab
1-PRESS THE BRIGHTNESS KEY ON THE REMOTE. 2-PRESS THE FREEZE KEY ON THE REMOTE.3-PRESS THE MENU KEY ON THE REMOTE 4-PRESS THE ENTER KEY ON THE REMOTE. THE SCREEN WILL BLINK BLACK ONCE AND ALL CODES ARE RESET.I CALLED AKAI AND THEY WILL NOW HELP OTHERS-THEY SAY.
Also try this:
http://www.ehow.com/how_7364537_reset-password-akai-tv.html
Please post back if it helps.
Jan 27, 2011 | Televison & Video
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
2,242 people viewed this tip
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
