Home | All Products | StreetPilot C330 (010-00401-10) GPS Receiver | Tips
Full Reset to original factory status May cure many problems
OTRdriver
By Apprentice OTRdriver
Rank: Apprentice
Rating: 73%, 245 votes
posted on Sep 21, 2007
Somewhat Helpful
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
Was this helpful?
Yes
No
35 people thought this was helpful
Comment #1
posted on Aug 10, 2009
imbmetz1
By Guru imbmetz1
Rank: Guru
Rating: 91%, 321 votes
This tip/trick is mis categorized! its under magellan 3140 and this tip l@@ks like its for a Garmin Nuvi
Comment #2
posted on Aug 08, 2009
swoopest
By Apprentice swoopest
Rank: Apprentice
Rating: 75%, 1 votes
I waited 60 seconds and the procedure never worked on my nuvi 270, even though the same instructions are contained in the help file on the unit itself.
Fortunately, I may not need to reset it. I was unhappy because it told me to drive the wrong way on 2 highway access roads...then I discovered it was in Pedestrian mode, and it would have been OK to walk the wrong way on sidewalks next to those roads.
Comment #3
posted on Apr 15, 2009
gcsi94142
By Apprentice gcsi94142
Rank: Apprentice
Rating: 0%, 0 votes
Great advice! Gives me hope. Have not been able to hold the screen and power buttons long enough to get to a white screen (even after 3 minutes) yet, but when I do I can attempt a full reset. Was afraid the way the screens were scrambling there might be moisture damage in the unit. Thanks!
Comment #4
posted on Feb 09, 2009
magbanuav
By Apprentice magbanuav
Rank: Apprentice
Rating: 0%, 0 votes
these tips really doesn't work on my unit (nokia 6110 navigator).i've been pressing and holding the bottom right corner which is the # sign together with the power button but still it did not work..the white screen appears but it directly goes to the main screen "on" while im still pressing the # sign and power button how long should i press and hold these 2 buttons so that i can restore my phone into it's original settings.thank you and hope to hear answers from you as soon as possible.many thanks
Comment #5
posted on Jan 21, 2009
gregcarolann
By Wiz gregcarolann
Rank: Wiz
Rating: 81%, 17 votes
Magellan Maestro units Reset button - look at the bottom of the unit , there will be a small hole on the left side. push this recessed button while unit is on. this should help ,if contact Magellan customer support.
Comment #6
posted on Jan 17, 2009
Dave_MICH
By Apprentice Dave_MICH
Rank: Apprentice
Could not get this to work with a Magellan Maestro 3210 where the 2008-09 map update destroyed the software. Turning it on flashes a white screen, but then it immediately goes to the the Magellan screen with a load bar undeneath.
Comment #7
posted on Jan 03, 2009
txguy9112
By Apprentice txguy9112
Rank: Apprentice
Rating: 0%, 0 votes
i tried this but my problem is that my unit wont power on at all i was trying to do the firmware update on it and it got stuck so i unplugged it from the computer and now i get nothing on the screen and when i plug into my computer it says it doesnt recognize my gps anywhere please help someone ASAP i just bought this and know it is broke.
Comment #8
posted on Dec 26, 2008
mdoddinkc
By Apprentice mdoddinkc
Rank: Apprentice
Rating: 0%, 0 votes
Follow htony's instructions, worked like a charm! Thanx!!
Comment #9
posted on Nov 28, 2008
zezo332
By Apprentice zezo332
Rank: Apprentice
Rating: 0%, 0 votes
Hello, i have problem. My friend give me NOKIA 330 with deleted some registry. I try this solution but when device starts i view NOKIA logo screen with this:
UPDATING IMAGE VIA USB:
USBUPDATE MUST BE 1.0.0.3
WAITING UPDATED INFO ....
If you have some solution for my problem , please help me. Thank You
Comment #10
posted on Aug 28, 2008
blakskorpion
By Apprentice blakskorpion
Rank: Apprentice
Rating: 0%, 0 votes
hi i have got evesham n20 sat nav,which was working fine until my mate borrowed it off me and when he gave me back,its not working properly.its not giving me guidance and am not getting voice instructions either.moterways,tolls and speed cameras are permanently disable on it,which were fine before.cant get hold of evesham and the website www.nav-cam.com which i used before to update my sat nav,thats vanished aswell.if any one can help me out.
Comment #11
posted on Aug 25, 2008
arleene
By Apprentice arleene
Rank: Apprentice
Rating: 0%, 0 votes
Awesome tip!! This worked for me! Thank you.
Comment #12
posted on Jul 25, 2008
haldorberge
By Apprentice haldorberge
Rank: Apprentice
Rating: 0%, 0 votes
What do you mean by hold the bottom right corner of the screen. It isnt a touch screen, so is it on the screen, under or where else?
Comment #13
posted on Mar 01, 2008
CALVOVO
By Apprentice CALVOVO
Rank: Apprentice
Rating: 0%, 0 votes
I BOUGHT MYSELF A FORTIS GPS NAVIGATOR AND IT CAME WITH THE ROUTE 66 SOFTWARE (SOUTH AFRICA), MY PROBLEM IS THAT THERE ARE PLACES THAT THE NAVIGATOR DON’T SHOW IN MY AREA/COUNTRY I KNOW THAT IT CANT SHOW ALL THE PLACES BUT I THINK SOME OF THEM ARE ON THE NEWEST VERSION, SO I ASKED AT THE SHOP WHERE I BOUGHT THE GPS AND THEY GAVE ME THE WEBSITE SO THAT I CAN UPGRADE MY SOFTWARE SO THE PROBLEM IS THAT WHEN I FOLLOW THE INSTRUCTIONS ON THE WEBSITE THE UPGRADE DOESN’T TAKE PLACE. I DID DOWNLOAD THE UPDATED VERSION ON MY PC AND WHEN I PUT THE SD MEMORY CARD FROM THE GPS INTO THE MEMORY CARD READER/WRITER IT SEEMS LIKE THE UPGRADE DOESN’T SEE THE ROUTE 66 IN THE SD CARD BECAUSE IT KEEPS ON SHOWING THE MESSAGE INSERT THE MEMORY CARD WITH THE ROUTE 66 AND IT DOES NOT UPDATE THE PREVIOUS VERSION, SO CAN YOU PLEASE TELL ME WHAT SHOULD I DO TO UPDATE THE VERSION THAT I HAVE OF RUOTE66 ON MY GPS.
Comment #14
posted on Jan 09, 2008
htony
By Apprentice htony
Rank: Apprentice
Rating: 85%, 2 votes
How OTRdriver's solution worked for me to clear up my StreetPilot C330 when it was stuck/frozen on "Acquiring Satellite" mode:
PROBLEM: Frozen screen @ “Acquiring Satellites” Full Reset to original factory status May cure many... ( DO THIS OUTDOORS TO RECEIVE SATELITTE SIGNALS ! ! ! ) Solution:
1- Turn off unit.
2- Press and hold the bottom right corner of the screen.
3- While still pressing and holding bottom right corner, press and hold power button and
continue holding both until a white screen appears (may take a couple minutes) with a
black dot.
4- Follow the on screen directions (pressing various dots that appear on the screen) and
Can you Help with these GPS Devices problems?
Garmin StreetPilot C330 (010-00401-10) GPS...
my garmin won't stay on in or out of the power source,...
cannot find new address or develpments i need to upload...
i would like to know how to update my garmin gps for free....
I have no maps loaded
How do I update my Garmin GPS for free ?
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Device Repair
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
