Tip & How-To about Health & Beauty
Keeping a clean and healthy toothbrush
Keeping your toothbrush clean can help to keep you from getting sick. You can do a few small things to help keep your toothbrush clean and help to keep yourself healthy. Many people keep their toothbrushes in containers or in a cabinet, but in reality keeping your toothbrush closed in a container helps to breed bacteria on your toothbrush. If you want to keep your toothbrush in a closed container then you should make sure that it is completely dry before storing.
Something that we never think about is washing our hands before we handle our toothbrush. Make sure to take a few second to wash your hands thoroughly before picking up your toothbrush, and then rinse off your toothbrush before you put toothpaste on.
Be sure to replace your toothbrush often and especially when necessary. According to the American Dental Association (ADA) you should replace your toothbrush every 3 to 4 months. Whenever you get sick you should replace that toothbrush right away when you get better so the bacteria doesn't stick around.
Keeping a healthy toothbrush keeps you healthy too!
Health & Beauty Logo
?why do only a few keys work on the remote
Some remote as they live on around your house area, they gather up dirt, or any debris laying around the house
I found some steps while searching around, here they are-
1 . Remove any batteries out of your remote control.
2 . Check over the remote control and remove any screws keeping the remote together.
3. Once you have it open, make a note of any switches or loose pieces so you will know where they go when you put the remote back together.
4. Clean the circuit board and keypad to remove any dirt and oil. An old toothbrush works. Check, after cleaning, if the remote is working again; dirt could be the only problem.
5. Clean the buttons, blow off any dirt inside the remote.
Feb 21, 2015 | Televison & Video
i pod not keeping charge
You will have to dismantle ipod and clean any corrosion of motherboard(may be causing shorting) with a soft toothbrush and some isopropanol alcohol also bottom of dock connector.Have a good look under a magnifying glass to see if any physical corrosions of pins etc. Dry off board and reassemble with new battery.
Try it out.
Some pins etc depending on corrosion my need resoldered.
First thing to go is the charging circuit on the battery when wet.
Feb 09, 2014 | Apple 160 GB iPod Classic (Silver) +...
Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
Feb 12, 2013 | Health & Beauty
What can I do to make sure my toothbrush stays clean?
In order to keep your toothbrush clean and germ free, you should do the following:
Rinse the toothbrush thoroughly after every use and make sure there's no toothpaste left.
When not in use, make sure that the toothbrush is away from other toothbrush or any other tools that could have germs on them.
Make sure that the head of the toothbrush is not covered because then it would get warmer, which will promote bacteria growth.
Feb 04, 2013 | Health & Beauty
What are the advantages of electric toothbrushes?
Electric toothbrushes are an excellent tool to keep your teeth clean and healthy. They offer many advantages:
They allow you to remove plaque more efficiently and quicker than manual toothbrushes.
You don't need to brush hard in order to get good results. This means that you are much less likely to injure your gums.
People who suffer from physical conditions like arthritis find electric toothbrushes as a great replacement to manual toothbrushes because they are easier to grip and you don't need to use as much physical power to get your teeth cleaned (the powered brushes do the cleaning).
It is more fun to brush with electric toothbrushes compared to manual toothbrushes, especially for children.
718 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
