Tip & How-To about Philips DVD Micro Theater Shelf System (MCD288) System
To view all region dvds
Model - MCD289 - Turn system menu to prefrence page - insert the following code 811502 - then change region to zero - all region dvds can now be viewed
Philips DVD Micro Theater Shelf System (MCD288) System Logo
HI THERE I GOT THE PHILLIPS MICRO DVD HOME THEATER MCD388 unfortunatelyTHE LAST SUMMER WENT TO THE UK AND THE USA AND I CANT PLAY ANY OF THE DVDs can anyone help me with a region code????
1. Ensure there is No Disc in the player
2.Press Remote Control (RC) "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not
entering the sub-item );
4.Press RC numeric key sequentially 811502(entery code,no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is
all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
Jan 15, 2011 | Philips MCD288/37 DVD Micro Theater System...
Philips MCD716
1.Press DVD "OPEN/CLOSE" key (RC (remote Control) or main unit) to open the DVD tray (note:if no disc on tray,then you have not to open it);
2.Press RC "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not entering the sub-item );
4.Press RC numeric key sequentially 811502(enter code, however no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is all code.
Nov 23, 2008 | Televison & Video
DVDV809-04
You need to convert your machine to an all-region player. The following hack works for Diamond Vision models 803 and 807 - there's a good chance it will work for the 809 provided they've used the same firmware for this model.
The region-free hack works as follows:
1.) Turn on the power and wait until the 'NO DISC' message appears, then press OPEN/CLOSE on the unit itself to open the door of the DVD player
2.) On the remote control, press SETUP. A menu will appear onscreen.
3.) Enter the following number sequence via remote: 1 3 8 9
4.) A different menu will appear. Your cursor should now be sitting in a box with the current region displayed. Use the UP and DOWN arrow keys on the remote control to display a specific region's numerical code, or select '0' (this is the number zero - not the letter o ... this is the region-free setting).
5.) Press ENTER and then SETUP to exit.
6.) Your DVD player will now play DVDs from all other regions. The code only has to be entered once. Powering down will not cause the Diamond Vision to lose its region-free setting. An added plus: it automatically senses PAL/NTSC signals but it will output to an NTSC tv set.
Sep 02, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Can't access the preferences tab
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 23, 2008 | Philips DVP-3005 DVD Player
1,313 people viewed this tip
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
