Tip & How-To about Computers & Internet
How to know the lowest MAC address for STP Root Election
I'm getting ready to take the Cisco 3925E CCNP switch exam, and I have what may be an elementary question. In all the guides I've read, and lab manuals that I've used, anytime there are multiple switches that can be the possible root, the MAC address's are shown in a very simple format....such as aaaa:aaaa:aaaa or bbbb:bbbb:bbbb or some other such simple address thus making it obvious. How about in the real world, or on Cisco exams? Do you need to convert the entire address to be sure or just a portion?
MAC addresses are in hexadecimal format ranging from 0-9 and a-f. It's pretty much sequential from there.
A mac address of 0020.01cc.de23 is lower than 0021.01cc.de23. Another example would be 0000.c0a7.ffc2 is lower than 000.c0a7.ffc3 Cisco3925E
Computers & Internet Logo
reset password Catalyst 4006 Ethernet Switch
Depending on the Supervisor Module model, most likely it's a standard Cisco's "password recovery procedure":
Connect to the console
Reboot the switch (power cycle)
Start pressing Ctrl-C till you get to the BOOTROM
Change boot configuration register to 0x2142 (confreg 0x2142)
Boot the switch. It will ignore confuguration and boot "empty".
Go to "enable mode".
Copy startup configuration to running configuration ("copy start run")
Change boot register back to 0x2102 (conf t -> conf 0x2102)
Write config (write mem)
Reboot
Good luck,
Mike / CCNP, CCDP, CCSP, CCVP
Headset Adapters for office phone system
May 03, 2016 | Cisco Catalyst 4006 Chassis ( 4006)
i just want to you that how manny salary provide to complete cisco ccent exam ,m
ok sir ..
step 1: My 1st Reason for Re install Windows Xp 2.RPU 3.1 not working.
So I am bhuvnendra re install windows xp2 this machine.
Step 2: install java+RPU 3.1
Step 3: SATA DVD drive disconnect .
Step 4: ON the system
step 5: safe mood black screen are display.
Step 6: any mood select booting o.s
Windows continue restarting.
my solution
Step : SATA DVD drive connect
system are properly booting and proper working.
please give me what is real problem in this machine.
Oct 13, 2012 | Cisco Advanced V3 Ccent Ccna Ccnp Home Lab...
Problem with cisco 2513 routers
Check what version of software do you have. Do "dir" command and look at the file name. If it contains "K9" in the name, then it has "crypto" functionality, if it doesn't, then you need to find it (however it will be quite a challenge, as these routers are end-of-life for a decade...)
Good luck,
Mike ' CCNP, CCDP, CCSP, CCVP, etc.
Cisco Compatible Headset Adapters for 7940 7960 etc
Mar 30, 2017 | Cisco Computers & Internet
Cisco 2851. I have no access to the router. No Ip Phone connectivity or internet access. Amber light is on the AL.
READ http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_creg.html
Apr 14, 2012 | Cisco 2851 Router
is it possible to study CCNP self and do the exam??
yes, offcourse but as concern with practicle side you should join Labs, or if you have CBT CD you can also learn yourself.
Sep 02, 2009 | Cisco IOS
421 people viewed this tip
David Payne
David Payne
