Tip & How-To about Cell Phones
Speedup your Mobile Phone
Always use minimum sized memory card which can boost up your phone an excelent level as the bulk memory card harm your processing speed and effect the device...
Cell Phones Logo
my nokia 3230 is slow what shall i do I have formated phone+memory card both but it have slow speed ?
Hello Abhijeeet,
First scan your memory card for virus using antivirus.
May be phone is slow due to virus.
After that you can format the phone.
Mar 26, 2011 | Nokia 3230
my mobile phones memory is low. why
hi, to free up some memory you need to do the following.
1, delete all messages in inbox, outbox,sent,drafts.
2, delete any pictures you dont need
3, delete any ring tones you dont use, most people never use the ones you get free with the phone so deleting these will free up loads of memory.
the reason your phone says low memory is because the memory card isnt counted in this low mem warning so you can transfer stuff to the memory card to free up memory on the phone.
you can also delete any contacts you dont need
May 14, 2010 | Nokia N97 Cell Phone
W910i hanging problems
The hanging problem might be as a result of the follow:
  1. Maybe there is a virus on your phone.
  2. Maybe the phone memory is full.
  3. Memory card also might be full or maybe the memory card has virus
  4. Your phone operating system might me corrupt.
Solution(s):
  • Try to delete the files on the phone memory and let's see what happens
  • Remove the memory card and put on the phone without it and see if the phone will still hang
  • Master reset the phone and see if phone will still hang
If you try all the above and your phone still hangs, then you will have no choice than to take your phone to a qualified phone repair shop for software restore. That is, computer will be used to format your phone and the phone software will be reinstalled afresh to its factory default state and you will not see any trace of hanging on your phone any more.
I wish you the best.
Dec 04, 2009 | Sony Ericsson W910i Cellular Phone
slow processing
check if your memory card that u have inserted is of how many GB, if more than 1GB reduce it to 1GB, sometiimes phones cannot take up so much high memory.
rate me.......
Jul 06, 2009 | Nokia e65 Cellular Phone
lg kg300 speed become very slow
How much extended memory are you using with your handset. The speed issue could be due to higher capacity memory card usage.
And about applications, so let me tell you, applications like Opera Mini are always been slow on LG KG 300.
Apr 05, 2009 | LG KG300 Cellular Phone
901 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
