Tip & How-To about Dyson DC35 Multi Floor Digital Slim Cordless Vacuum
When I called they indicated that the brush roller can be removed with a quarter. Which I was able to do. Cleaned out collected debrie with a pick. They recommended that I do not wash it.
Keep the brushes cleaned regularly. I used a pick to pull out the hair and dust bunnies. It took a while, but will be easier if done regularly.
I tend to want to wash everything with soap and water. They recommended not using water.
Dyson DC35 Multi Floor Digital Slim Cordless Vacuum Logo
My floor brush is not turning or picking up dog hair/dust, I took it apart and cleaned
Be sure to install a new belt, belts lose elasticity and need replaced once or twice per year.
Feb 08, 2017 | Vacuums
How do I clean spinning brush
HI, it's Jim from Crucial Vacuum!
Definitely do not submerge your brush roll in water. An easy way to clean your brush roll is to manually rotate it to help unearth any debris or clogs that may be hidden.
If you notice that there's a lot of hair strands, or carpet fibers you can use either a razor and a scissor to remove this debris.
With the majority of vacuums the brush roll comes off. Usually you remove the brush roll to either replace it or replace your belt. If the bristles on your brush roll are loose or worn down it may be time to change it.
You can purchase your replacement parts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 27, 2014 | Vacuums
I have a similar problem as many do with this model, "clean Roomba's brushes".. We took it apart last night, cleaned out all of the dust we saw. we removed the cover, the housing for the brushes and everything else we could. Still has the same problem. What now?
The machine is trying to tell you that there is something still restricting the brushes being able to rotate. The brushes are spinning on an axile that might have some hair or carpet fibers caught in it still. Look on the outer edges of the brush assembly and see if any of these things are rapped around those ends. Cleaned that off and put a little WD-40 in there and that should get you going.
Dec 03, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba Discovery 4120 barely moving
I don't have the same roomba that you have, but I had a lot of dog/cat hair stuck on the fan in the trash bin section. Once I removed that it started to work again. I used an air compressor to give it a really good blow out.
Here is a link that might help you out.
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=10960
Phil
Dec 27, 2008 | Roomba Robotic Floor Bagless Vacuum
1,861 people viewed this tip
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
