Tip & How-To about Hotpoint TDC32 Electric Dryer
Once you have established if the problem is the thermostats, remove them from machine. In the centre of the plastic disk on the back of thermostat dead centre between the terminals is a little indentation, this is where the reset button used to be. Use a 1.5mm drill bit and CAREFULLY drill through this indentation through the plastic casing, when you have gone all the way through, place a 1mm dill bit through the hole and press down, you will hear a little click - Congrats - you have just reset your thermo!! Refit and test - Worked like a dream for me.
