Tip & How-To about iRobot Mirra 530
Example: How to change your mp3 player background
Follow these steps to clean and maintain your Mirra for the longest life possible.
1. Ensure the Mirra is disconnected from the power-supply
2. Rinse the filter as shown in the image below after each cleaning cycle.
You can also view a video here: http://www.fixya.com/tippage.aspx?thid=20133874&mt_f=tip_capture
3. Clean the scrubbing (roller) brush by removing any debris that might be wrapped around it.
  • Position Mirra upright (fig. 1 below), so you can view the scrubbing brush
  • Push the end cap of the brush inward, using a screwdriver, and pull out the roller (fig. 2 below)
  • Place the newly cleaned brush in the Mirra, snapping the end cap into place until it clicks (fig. 4 below)
4. Check the propeller as follows. REMINDER: BE SURE THE POWER-SUPPLY IS DISCONNECTED FROM THE MIRRA BEFORE CHECKING THE PROPELLER
  • Remove the filters from the Mirra (fig. 1 & 2 below), if not removed already.
  • Unscrew the propeller top cover using a Phillips head screwdriver, counterclockwise (fig. 3 below).
  • Remove the cover (fig. 4 & 5 below)
  • Remove any debris from the propeller (fig. 7 below). Note: there is no need to clean out the pump motor.
  • Place the propeller top cover back onto the robot (fig. 8 below)
  • Screw the cover back into place, by screwing the screw in clockwise (fig. 9 below)
5. Straighten out the floating power cord periodically, so it doesn't develop kinks over time.
Information acquired from iRobot Solutions
iRobot Mirra 530 Logo
604 people viewed this tip
Top iRobot Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an iRobot Pool and Spa Expert? Answer questions, earn points and help others
