Tip & How-To about Sharp LC-26D6U 26 in. LCD Television
How To Fix Most Sound Problems
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of ‘Aureius’ on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Sharp LC-26D6U 26 in. LCD Television Logo
My Sharp LC-26D6U has lost Audio. How can I fix that?
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure. Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ?2502 Heat Kit? is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from partstore.com for $19.95. However, it?s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95, also from partstore.com. Please note that board replacement for this problem is almost never necessary, so if you?re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board. If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ?important service references? by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ?buried? under other boards. Please also refer to post # 373 at: avsforum.com/avs-vb/showthread.php?t=647174&page=13 for some ?pics? of the information detailed here. My knowledge of how to solve this issue came primarily from finding the research efforts of ?Aureius? on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy! I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Oct 08, 2009 | Sharp LC-26D6U 26 in. LCD Television
LC-32D6U GETTING NO SOUND
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (rubbing alcohol works quite well). Despite what the images say,
YOU MUST REMOVE ALL BLACK RESIDUE FROM BOARD. IT WILL NOT WORK IF ALL THE RESIDUE IS NOT REMOVED.
This kit is Sharp Part Number: PSPKIT663WJZZ and is available from Partstore.com for $19.95. http://www.partstore.com/Part/Sharp/Sharp/PSPKIT663WJZZ/New.aspx
It’s possible to get the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. http://www.partstore.com/PartSearch.aspx?PartNumber=PSPAZA663WJKZ&hiddenInputToUpdateATBuffer_CommonToolkitScripts=1&x=26&y=14
Jun 21, 2009 | Sharp LC-26D4U 26 in. LCD Television
No sound on Sharp Aquos 37' LC-37D4U
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
Jan 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
Aquos lc-26D6U no sound
Dec 14, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Sharp TV Audio Problem
Sep 15, 2008 | Sharp LC-26D6U 26 in. LCD Television
3,120 people viewed this tip
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
