Tip & How-To about Office Equipment & Supplies
Keep labels from coming off
It seems like its inevitable, you print your own labels at home and then a few months or even weeks later those labels are starting to peel off. With one small tip you can keep those labels from coming off. What I have been doing with the labels that I put on my kids school supplies is rounding off the corners. After I print the label and trim it down to size I just trim off the corners to make them round and it works wonders. This works simply because when you have a sharp corner it is easy for stuff to get in under the label and then before you know it the whole thing is coming off. By rounding the edges you make it harder for stuff to get under it.
Zebra Z4M won't print whole label
Did u try system restore?It will restore all of ur settings to how they were when it was working...
Oct 08, 2007 | Zebra Z4M Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer is not set for "tear off label". My old Zebra 2442 would extend the label out so the perforation of the 4x6 label was right at the cutter. When it printed a new label it would backfeed it just a little bit before starting the print. My LP 2844 doesn't do that. The result is that I either lose whatever is left on that label that's printed, or I hit the feed button and waste the entire next label. In Advanced Setup -> Device options, I've tried setting "Peel off" and "None" also tried checking "Reverse Sensor". Media is set as 4x6 and it's been calibrated. Media type is set to "Label with gaps". Thanks! -brian
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
Won't start every time, when it does runs rough
test fuel pump pressure seems like its faulty i think your right
Jan 03, 2010 | 1996 Ford F150 Regular Cab
AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Dec 31, 2008 | Avery 9100 Thermal Printer
948 people viewed this tip
k24674
jasbo
jasbo
