Tip for Engine 8 Hp
WARNING: Do not allow PW to run "dry"
posted on Apr 15, 2009
jj505
jj505
Rank: Guru
Rating: 91%, 244 votes
It is recommended that once pressure washer is in operation and water flow thru wand is there ,that you do not allow off period between burst of no more that 2 minutes or you highly risk damage to your pump,not engine, due to overheating. See if Dump valve is adjustable,cheaper models not adjustable. This valve senses pressure/heat build up in pump when trigger is released, and is a secondery backup to release such heat/pressure to avoid pump failure. If you have repeatly left trigger off for more than 2 minutes in for prolonged periods of time,this is not good.
Thanks and Please Rate a Fix Ya
John jj505
Somewhat Helpful
Was this helpful?
Yes
No
Add a Comment
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
Can you Help with these Pressure Washers problems?
Answer
For pressure washer Model WP-2402-SWHB, SN 10132043: With Honda engine running, or no engine... (More)
Answer
It spits gas out of the carburetor when I try to start it! Generac with a G24 engine 5.5 honda
Answer
karcher kb4.99 low pressure 4yrs old
Describe your problem:
Select a Category:
Insert Link
Insert Image
Insert List
Insert List
Spell Check
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Garden & Power Tool Repairmen
in San Mateo, CA
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
