Tip & How-To about Garden
Haste to stop waste!
Too often we let our irrigation systems go on without really making sure that the amount of water, the pressure, the radius and other settings are what our lawn or landscape needs.
This causes not only a great waste of water and money but it may also ruin our flowers and plants.
Therefore here are a few tips to transform a wasteful sprinkler irrigation into the effective system it should be, and to keep a healthy landscape, lawn or garden.
1. When to water.
Watering your lawn and landscape should be differentiated according to seasons.
During warm months (May to October) irrigation should be activated between midnight and sunrise, so to minimize the water that evaporates.
While during winter, plants and lawns should be watered during the warmer part of the day to prevent water from freezing on the landscape.
2. Don't drown your plants.
Keep an eye on your lawn while the sprinklers are on and monitor when the water starts dripping off the sides. This way you will know how long your sprinklers should be left active for, so that the plants may absorb the water without being overwhelmed.
3. Avoid daily, light watering.
4. When watering plants with deep roots, water well and deep, until about half inch deeper than the deepest roots, in order to encourage downward growth.
5. When watering on a slope do it gradually. Run your sprinklers every 3 hours circa and aerate to increase infiltration.
6. Check your sprinkler's efficiency once a month.
Check for damaged, leaking, clogged or stuck sprinkler heads and for constantly soaked patches of grass or soil to detect leakage.
Make sure that the water is sprayed all over the area and that new additions or plants that grew higher and larger don't block the spray pattern.
7. In seasons in which the temperature reaches 30/32 degrees Celsius remember to run your sprinklers 5 to 10 minutes in the afternoon to cool the area. It reduces the symptoms of summer patch disease.
8. Create water zones by putting together the plants that have similar water needs, and water them accordingly
9. Be careful when mowing. If your sprinkle heads don't retract underground after irrigation, apply small flags on them so that while mowing you see them better and avoid damaging them.
Garden Logo
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Sep 10, 2013 | Garden
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
irrigation system problem
How big is your pump? How much HP rating? It could be a case of blocked water line. Just check your pipe lines and the gate valve for blockage. Just your e-mail
for your comments.
Jul 04, 2009 | Plumbing
755 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
