Tip & How-To about Computers & Internet
Increase the speed of computer
The speed of computers depend on several things.
In your case >>>>
1. Check the hard disk ... Go to My Computer >>> Right click on C: >>> Properties >>> Disk Cleanup (to remove useless files) ... Again from Properties >>> Tools >>> Check Now >>> Tick on ( Automatically fix file system errors & Scan for attempt recovery of bad sectors) >>> Start >>> The computer will schedule the scan to the next start up, so restart the computer ;) ..... After finishing the scan go again to C: >>> Properties >>> Tools >>> Defragment Now >>> a new window will appear , click on Defragment button ...
By the way make sure that the hard disk isn't full. If it's , try to move some personal files to another place such as D: or burn them on CDs , try to remove useless programs, Start >>> Control Panel >>> Add or Remove Programs ...
2. 256MB of ram is quiet slow reallly at least 1 GB would help your computer loads. You just need to stop some unnecessary programs working ( Be careful the following steps maybe harmful to your computer ( If try to change the setting ), so don't change the setting of the system)... Start >>> Run >>> Write ( msconfig ) >>> Ok >>> A new window will appear ( be careful here DON'T TRY TO CHANGE OR EDIT ANY SYSTEM OR BOOT FILES OR SETTINGS UNLESS YOU KNOW WHAT ARE YOU GOING TO DO) >>> Click on Startup ( This window shows the programs, which are running in the startup) >>> Remove ticks from the programs, WHICH YOU KNOW THEM, to stop them running in the startup ( this step is really useful to speed the computer up) ... By the way the computer will ask you (after restarting) about that change in the startup, just press ok and tick on (Don't ask me this question again).
3.Increasing the performance of the computer ... Right click on My Computer >>> Properties >>> Advance >>> ( Performance field) Setting >>> Here you can increase the performance by choosing (Adjust for best performance) and you can leave some visual effects if you like ( this step isn't harmful,but don't go to Advanced if you haven't experienced it)...
By the way, sometimes, having two virus protection together makes the computer works like a turtle :)
You should Only have and only need ONE virus protection installed on your PC.
You can click start-----click run-----type msconfig------click startup tabs,then you can uncheck programes that dont need to run at startup. Then click ok to exist..And you also can go visit http://www.make-pc-fast.com to download a speedup software.
Computers & Internet Logo
MY COMPUTER NEEDS MORE RAM,I DONT HAVE ALOT DOWNLOADED,I DONT USE A DISPLAY PICTURE FOR MY DESKTOP AND NO SCREENSAVERS, SO MY QUESTION IS HOW CAN I GET MY COMPUTER TO RUN FASTER UNTIL I CAN PURCHASE RAM?
Hi I recommend using these methods:
1., download and install GameXP from http://www.theorica.net/gamexp.htm, this is a very good system booster
2., download ccleaner and run the registry cleaner part http://www.piriform.com/ccleaner/download
3., go to star > run > msconfig and remove everything unnecessary from Startup
Mar 09, 2011 | Microsoft Windows XP Professional for PC
my pc is slow,how i will make it faster to work
back up the files you want and reinstall windows for a fresh start.
Mar 07, 2011 | Microsoft Windows 7 Home Premium 64BIT...
my WD 1TB hard disk drive shows me loaded with 300GB capacity of folders but when they are not seen on my pc
1) Open any folder on your your computer and go to: Tools > Folder options > View tab > check "Show hidden files and folders" and uncheck "Hide protected operating system files". 2) Look at your hard disk again, if you still can't see any files on it, there must be an error of your disk. To solve it, go to: My Computer (or Win+E keyboard shortcut) > Right click on the drive representing the 1TB hard disk > Properties > Tools > Check Now... > Check both boxes to fix errors.
Mar 07, 2011 | Western Digital My Book Essential Edition...
i cannot use my usb or flask drive because it is write protected
4 different ways how to eventually solve this problem:
1) Try a program Thumbscrew (http://www.irongeek.com/i.php?page=security/thumbscrew-software-usb-write-blocker) which switches storage devices' write protection on or off.
2) Or do the same thing manually, by go to Start > Run > type "regedit" > Ok HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\StorageDevicePolicies\WriteProtect
Value 1 is for "on" and 0 for "off".
3) Plug the USB hard driver in different USB slots on your computer, maybe one of them is faulty.
4) Disable the Disk Write Caching of the relevant USB hard disk drive:
  1. Right-click My Computer, and then click Properties.
  2. Click the Hardware tab.
  3. Click Device Manager.
  4. Click the plus sign (+) next to the Disk Drives branch to expand it.
  5. Right-click the drive on which you want to enable or disable disk write caching, and then click Properties.
  6. Click the Disk Properties tab.
  7. Click to select or clear the Write Cache Enabled check box as appropriate.
  8. Click OK.
Mar 06, 2011 | Kingston Computers & Internet
Dell Dimension 4600----Online the pages take a long time to load. Not all the graphics load sometimes, so the page freezes.The graphics from installed programs or My Pictures show no signs of any problems.
1. check the capacity of the hard drive
a. go to "my computer/or in the case of Windows 7 "computer under the Windows
Orb.
b. highlight the drive then right click to see the drive capacity unused space will be in the
pink area,
c. clear your browser temp folder, history, and cookies
d. remove unwanted programs from the startup menu>> For Windows 7
1. click the Windows Orb then to >> all programs >>>select "start up folder" right click on
the program you want not to be in the start and delete it.
The same procedure for Windows XP except it will be under the "start button"
2. Remove any items that you don't use in the task bar
3. uninstall any programs and or documents that you don't use
4. update you anti-virus software
  • 5. defrag your hard drive >>>check help guide located under the Orb in Windows 7 and type in "defragmentation
visit here to see the video and the instruction
http://windows.microsoft.com/en-US/windows7/Improve-performance-by-defragmenting-your-hard-disk
Oct 07, 2010 | Dell Dimension 4600 PC Desktop
1,018 people viewed this tip
David Payne
David Payne
