Tip & How-To about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fisher Paykel Fridge E522BRX Not cold enough !!!
After one year, I just found out that the temperature setting works the opposite way of other "american fridges" The temperature control is like a termometer so, when you think you put it colder up the thermometer...is goes warmer!!@#$%%!!! Was I ever dumb???
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
2,211 people viewed this tip
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
