Tip & How-To about Brookstone CKD5810A Clock Radio Smart Set Compact Disc Digital Audio
Change time and date
Hold down the time or month/date buttons, then press either of the '<< or >>' (by CD controls) to move the time, or month/date. To change the year hold down both time and month/date buttons together to adjusting the year using the '<< or >>' buttons.
Brookstone CKD5810A Clock Radio Smart Set Compact Disc Digital Audio Logo
how do you change the time on a dymo datemark
Hi there!
Here's what you can do"
1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
Note: The unit will revert back to normal display if no other key is pressed for 10 seconds
2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print..
Hope this helps!
Vikroks
Mar 29, 2011 | Dymo DateMark Date/Time Stamper
How do I set date and time?
  1. To set the current date and time, press and hold down the SET/EDIT button for 2 seconds, let go and the Month (M) and Day (D) indicators will start flashing.
  2. While the Month (M) and Date (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format, press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR and MINUTE fields. The field that is currently active will start flashing. To change a field's value press the LOCK button, each stroke of the Lock button moves one value up.
  4. Once you are finished setting the Date and Time press the SET/EDIT button to return to normal display.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189, and back up to the current year. Be cautious when setting the year
Resource 1: Dymo Date Mark Electronic Date/Time Stamper Manual
Feb 17, 2011 | Dymo Date Mark Electronic Date/Time...
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Jun 08, 2009 | Microlife 3MQ1 Blood Pressure Monitor
reset time
Nov 05, 2007 | Dymo DateMark Date/Time Stamper
1,784 people viewed this tip
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
