Tip & How-To about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows XP Shortcuts
Copy. CTRL+CCut. CTRL+XPaste. CTRL+VUndo. CTRL+ZDelete. DELETEDelete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETECopy selected item. CTRL while dragging an itemCreate shortcut to selected item. CTRL+SHIFT while dragging an itemRename selected item. F2Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROWMove the insertion point to the beginning of the previous word. CTRL+LEFT ARROWMove the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROWMove the insertion point to the beginning of the previous paragraph. CTRL+UP ARROWHighlight a block of text. CTRL+SHIFT with any of the arrow keysSelect more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keysSelect all. CTRL+ASearch for a file or folder. F3View properties for the selected item. ALT+ENTERClose the active item, or quit the active program. ALT+F4Opens the shortcut menu for the active window. ALT+SPACEBARClose the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4Switch between open items. ALT+TABCycle through items in the order they were opened. ALT+ESCCycle through screen elements in a window or on the desktop. F6Display the Address bar list in My Computer or Windows Explorer. F4Display the shortcut menu for the selected item. SHIFT+F10Display the System menu for the active window. ALT+SPACEBARDisplay the Start menu. CTRL+ESCDisplay the corresponding menu. ALT+Underlined letter in a menu nameCarry out the corresponding command. Underlined letter in a command name on an open menuActivate the menu bar in the active program. F10Open the next menu to the right, or open a submenu. RIGHT ARROWOpen the next menu to the left, or close a submenu. LEFT ARROWRefresh the active window. F5View the folder one level up in My Computer or Windows Explorer. BACKSPACECancel the current task. ESCSHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing. Use these keyboard shortcuts for dialog boxes: To PressMove forward through tabs. CTRL+TABMove backward through tabs. CTRL+SHIFT+TABMove forward through options. TABMove backward through options. SHIFT+TABCarry out the corresponding command or select the corresponding option. ALT+Underlined letterCarry out the command for the active option or button. ENTERSelect or clear the check box if the active option is a check box. SPACEBARSelect a button if the active option is a group of option buttons. Arrow keysDisplay Help. F1Display the items in the active list. F4Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts: Display or hide the Start menu. WIN KeyDisplay the System Properties dialog box. WIN Key+BREAKShow the desktop. WIN Key+DMinimize all windows. WIN Key+MRestores minimized windows. WIN Key+Shift+MOpen My Computer. WIN Key+ESearch for a file or folder. WIN Key+FSearch for computers. CTRL+WIN Key+FDisplay Windows Help. WIN Key+F1Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ LOpen the Run dialog box. WIN Key+ROpen Utility Manager. WIN Key+U accessibility keyboard shortcuts: Switch FilterKeys on and off. Right SHIFT for eight secondsSwitch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREENSwitch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCKSwitch StickyKeys on and off. SHIFT five timesSwitch ToggleKeys on and off. NUM LOCK for five secondsOpen Utility Manager. WIN Key+U shortcuts you can use with Windows Explorer: Display the bottom of the active window. ENDDisplay the top of the active window. HOMEDisplay all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)Collapse current selection if it's expanded, or select parent folder. LEFT ARROWDisplay current selection if it's collapsed, or select first subfolder. RIGHT ARROW
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
cant see option to log out/sign out on facebook from Lenovo g50 laptop
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Oct 02, 2014 | Computers & Internet
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management Windows key + E = Explorer ALT + Tab = Switch between windows ALT, Space, X = Maximize window CTRL + Shift + Esc = Task Manager Windows key + Break = System properties Windows key + F = Search Windows key + D = Hide/Display all windows CTRL + C = copy CTRL + X = cut CTRL + V = paste Keyboard Shortcuts [Alt] and [Esc] Switch between running applications [Alt] and letter Select menu item by underlined letter [Ctrl] and [Esc] Open Program Menu [Ctrl] and [F4] Close active document or group windows (does not work with some applications) [Alt] and [F4] Quit active application or close current window Ctrl] Lft., Rt. arrow Move cursor forward or back one word Ctrl] Up, Down arrow Move cursor forward or back one paragraph [F1] Open Help for active application Windows+M Minimize all open windows Shift+Windows+M Undo minimize all open windows Windows+F1 Open Windows Help Windows+Tab Cycle through the Taskbar buttons Windows+Break Open the System Properties dialog box explorer shortcuts END....... Display the bottom of the active window. HOME....... Display the top of the active window. Type the following commands in your Run Box (Windows Key + R) or Start Run devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator mspaint = Microsoft Paint wmplayer = Windows Media Player control = Opens the Control Panel Internetbrowser type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it For Windows XP: Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the previous paragraph. CTRL+UP Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Refresh the active window. F5 Cancel the current task. ESC
Oct 12, 2010 | Computers & Internet
neeed key board short cuts
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Feb 17, 2011 | Computers & Internet
382 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
