Tip & How-To about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Find your only getting Luke warm water @ your faucets??
This is a common fault with new to used installed waterheater.
It is call a diptube ,made of pvc in part description. It is located on cold inlet,top of waterheater.
Malfunction of dip tube is usually a fracture caused by age mostly,or faulty install when new and tube was exposed to high heat from welding .
This tube allows the cold water supply to flow into W/heater and exit at bottom where it is heated while pushing already heated water to hot side and to your faucet. If this tube is defective ei...cracked the cold will [leak] mix with the hot before reaching bottom to be heat..thus lukewarm water syndrome. Solution $8 part H/depot>remove coldside copper fittings and pull white pvc out,about 4feet long,less rotted area, install new 3/4 inch pvc dip tube with flange up.
Thanks jj505 The HomeRepairman
jthomefix@gmail.com
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
how to how to install the anode rod - for extended warranty - in a new Rheem waterheater?
You are installing a combo anode rod that replaces hot water outlet nipple. This means you will have 2 anode rods, which doubles the anode capacity of tank, which can cause extended life of water heater, assuming that both anodes are inspected each 2-5 years.
Sounds like a heat trap insert is in the way.
Look at parts sheet that comes with product manual.
Pull insert out since it will cause clogs.
Same insert is on cold side nipple.
I want you to contact the Tank forum since they are anode experts:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Tank will recommend magnesium anode and not aluminum.
My understanding is that Rheem water heaters are made so only Rheem brand anodes fit their tanks. While other companies use generic anodes that are sold at any plumbing supply, and also sold at Tank website.
You can configure pipes to make heat traps that save save $2-4 per year on gas water heater operation.
http://waterheatertimer.org/images/Heat-trap-install-900.jpg
http://waterheatertimer.org/How-to-maintain-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 08, 2012 | Water Heaters
on demand hot water heater leaking
is this an area w/a threaded fitting?if so ,you turn off waterheater,drain,disconnect existing fitting,clean and rewrap with new teflon tape ,and retighten down.i only say to drain,because i am not sure if it is hanging and would not want to fall on you.teflon tape and rewrenching down should fix,unless soldered.then call your plumber.also if under warr.from installer ,less than 1 yr.,call them and tell them to fix it for free.i have over 13yrs in sheetmetal install,both in hvy.industrial down to many other types of home install of furnaces,a/c units,retrofits in /new and existing homes,waterheaters,garbage disp,refrig.water lines,gas etc
May 21, 2012 | Bosch Water Heaters
water heater leak
There should be a cut off vave installed on cold water inlet a top of waterheater if not there you will need to cut off at meter,curbside.
Please rate. Thank you. jj505
Mar 30, 2009 | Water Heaters
Water heater ground
You have clearly lost your ground due to PVC. One solution would be to run copper ground wire from the hot water tank to the metal splice on each end of the PVC. It is not necessary to go all the way back to the breaker box.
Jan 23, 2009 | Water Heaters
792 people viewed this tip
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
