Tip & How-To about Microsoft Windows XP Professional
Get the "Administrator" name on Welcome Screen
To get Admin account on the "Welcome Screen" as well as the other usernames, make sure that there are no accounts logged in.
Press "ctrl-alt-del" twice and you should be able to login as administrator!
finally worked for me after i found out that all accounts have to be logged out first
Microsoft Windows XP Professional Logo
locked administrator
For Windows Password:
1. Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box.
2. Type \Administrator\ (without quotes) in Username and leave Password field blank.
3. Now press Enter and you should be able to log in Windows.
Now you should be able to reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Log in screen.
Oct 10, 2013 | HP Compaq nx7300 Notebook
I have a toshiba satellie pro (A105), I forgot my password, now I want to restore to factory settings (im order not to loose the genuinity of my windows)..... I dont have any recovery CD, what do I do?
If you have Windows XP press CTRL+ALT+DEL at the login screen.
A new login screen will appear. Login using Username: Administrator and Password: password
This will log you into the Admin account.
You can then go to the user account in the control panel and reset the password for your user account.
Hope this helps!
Regards
Nov 27, 2010 | Toshiba Satellite Pro L300 Notebook
Trying to load windows xp service pack 2 forgot my password
For XP professional
When the computer gets to the login screen hold down both Ctrl and Alt and then hit the Del key twice. A new login window will appear.
In the top pane type administrator and hit enter. Hopefully you can log in as admin. If it lets you in go to the control panel and select "User Accounts" select "Change an Account" and the click on your account and remove the password. Click Apply and log out.
You should then be able to access your account.
For XP Home
Restart the computer and repeatedly press F8 until you see a list with safe mode at the top. Navigate to safe mode using the up cursor key and hit enter. You will see white text on the screen, this just means its loading up its basic drivers, so be patient!!
When you get to the login screen click on administrator and let it load up. Now all you have to do is go to the control panel, user accounts, change an account, click on your account and remove the password.
Please post back if you need anymore advice.
Good luck.
Jan 11, 2010 | HP Compaq nc6230 Notebook
how do i unlock my computer if i forgot my username and password
As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type \Administrator\ (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
Windows password reset software:
for example:Windows Password Reset. It is easy and convenient to use.
http://www.resetwindowspassword.com
Oct 05, 2009 | Computers & Internet
Window will not reboot after
try leave the password blank.
you know? When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So try to logon as adminstrator ,here is the guide:
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
if that doesn't work,then just learn from others how to reset windows password with Windows Password Recovery Tool.
Nov 02, 2008 | Gateway M275 Tablet PC
425 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
