Tip & How-To about Computers & Internet
GRANDFATHER WISDOM PAST DOWN
Great tip my Granddad told me when I was younger...
1) Don't tell a lies, ( no man is smart enough to remember all the lies told, you'll end uo lonely, and if you get into the habit if not telling lies - you wont from that habit and have a happier life
2) Don't hold grudges - Grudges trun into sickness, Holding onto angry is the first step to dying younger.
3) drink a 40oz of Booze a month .. providing your doctor says it is okay.. it will help you blood, keep bladder clean and you'll be more fun.. happier = healthier
4) Don't stack anything in your ear smaller than your elbow.. Needs no explaining....
My granddad live by this code and so did his sister.. Popa died at 95 and his sister 106
cheers, all.!
Computers & Internet Logo
Once I turn on this acer aspire one little laptop I can't get into windows 7 starter I don't know the password
LOL, ok why don't you know the password? If you're smart enough to set the password, surely you're smart enough to remember it.
Unfortunately, microsoft made the password security so much tighter in windows 7. Everyone that has windows 7 and put a password on their userid should take the time to create a Password Reset Disk. Otherwise you've got to spend some money to get into it. There are lots of claims that this or that software will unlock it, but some may just be scams for money. The surest way is to reinstall your operating system.
Apr 14, 2012 | Acer Computers & Internet
i have a 1966 mustang 3.3l. i just purchased a new engine & i can't get the harmonic balancer to fit right. it's scrubbing against the timing cover when its tightened down. it seems like there should be a spacer or something. i called tech support at the place i bought the engine & was told that either the timing cover wasn't tightened enough or that i'm missing an 'oil slinger'. he said that was the technical term for it but when i googled i got nothing. he said it was a thin metal ring appox 2-3inches in diameter that slid on the crankshaft between the timing gear & the balancer. he said if i had this part on the i wouldn't be able to see the gear behind it. i think this is the part i'm missing but that 'oil slinger' isn't the technical term. i really think i'm missing a part.
66 L6 200. Are the timing marks easy to see? I just did this last week on our 66 block. Just bring it to TDC on #1. Remove the pulley/dampner and the timing cover bolts. Remember to remove the front oil pan bolts to the timing cover.
I use an impact wrench on the cam bolt while holding the crank bolt so I don't slip out of TDC. You'll then have to remove the oil slinger. It just slips off the keyway on the crank snout. Carefully pry the cam sprocket to start wiggling it off the cam. Both the cam and crank sprockets are "keyed".
Get the new sprockets and chain aligned with their marks. Slip the crank sprocket on first until the cam sprocket needs mounted. Just remember to hold the crank, cam sprocket, and chain as an assembly when mounting. Once you get the cam sprocket started, start threading the bolt to hold it in place. Tap light a rubber mallet to seat it further on the end of cam.
I would then remove the cam bolt and coat it lightly with thread-loc and then thread it back in. You don't want it backing out later when your driving down the road. ( don't ask how I know). Remember to put the oil slinger back on.
Your Engine has an oil slinger.
Wayne
Jun 28, 2011 | 1966 Ford Mustang
Hi I need a parts and repair manual for the yardman 12a-978q452 mower , I can not finded on line.
I know this was more than a year ago, but I just got one second hand and had to find the same thing. It's made by MTD in Canada. Here's the site to find it. They don't have the manual for the exact same model number, but I've gone through it enough to know it'll work. http://www.mtdproducts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10500&catalogId=20500&langId=-1
May 06, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Samsung Mobile Phone;Model SGH-i200 will not retrieve incoming mms photos and will not send photos attached to sms (says I need to set up profile??) Thanks
It's one of two things. 1: the programing in your phone might be messed up, so you may have to take it into your provider store. Odds are though there won't be anyone smart enough to do anything about it (even though they do have the capabilities), so you might have to send it to the manufacturer. 2: Most likely your provider has blocked your internet service. Most smart phones can't send or receive MMS's if the subscriber decides to cancel there internet services. I think it's just a way to get you to pay for something you don't want. Non smart phones (that don't even have internet capabilities) are able to send and receive MMS's without having to pay for internet service at all, unfortunately most phones now are smart phone based even if they're not called as such. You don't have to get a plan for internet service, but you will end up paying for each kb you use to send and receive each MMS. If you do send and receive a lot of them you might actually be better of getting an internet plan. Ether way it sucks that we have to pay twice. I mean if we pay to send why does the other person have to pay to receive? Isn't it already payed for? Even when it's physical we don't pay to receive a package as well.
Mar 31, 2011 | Cell Phones
Upset Granddad. Removed his radio and don't have the code.
The other number (apart from the main Serial Number ) required for a Peugeot Radio Code is the SECURITY CODE which is in the format TOA123 or TA123 or just A123 at the end of a barcode.
What I suggest is POST A NEW QUESTION quoting ALL the LETTERS+NUMBERS from ANY LABELS , BARCODES or STAMPED IN THE METAL CASING and I should be able to help
Sep 19, 2009 | Car Audio & Video
799 people viewed this tip
David Payne
David Payne
