Home | All Products | FLM-2632 Television | Tips
My LCD TV has sound but no picture.
ginko
By Guru ginko
Rank: Guru
Rating: 89%, 4894 votes
posted on Apr 10, 2009
Very Helpful
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Was this helpful?
Yes
No
37 people thought this was helpful
Comment #1
posted on May 06, 2009
cg207005
By Apprentice cg207005
Rank: Apprentice
Rating: 0%, 0 votes
Very useful post.
Do you know where to purchase service manuals? Also, what would be the default voltage for the voltage board? I am one month past my service warrenty and a local service repair wants $800 to fix my TV. Unreal.
Can you Help with these Flat Panel Televisions problems?
Polaroid FLM-2632 Television
There is a very loud static electricity sound through the...
i have a coby TF-TV1901 (19"lcd flatscreen).hooked...
I can't get the tv to display full screen on reg. or hd...
dog eat remote, replacement remote does not work tv, need...
When we turned on the tv it says no signal vga input? It...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
