Tip & How-To about Proxxon Micromot 3 Jaw Keyless Chuck Model 28941
Metric threads
This chuck has metric 8mm-0,75 threads and will not fit a dremel.
Proxxon Micromot 3 Jaw Keyless Chuck Model 28941 Logo
What size is the adjuster bolt on a 94 isuzu rodeo 3.2 power steering pump
measure it.
measure the place if fits, match it. it's metric, not imperial inches.
or call isuzu.
or find a mechanic, he will do the measure and fit it.
all ASE mechanics can to this blind folded.
my guess 8mm.
I can not teach you how to measure things.
I uses 2 tools.
a caliper
and thread pitch gauge.
(or from a box of old metric bolts, trial and error way)
Dec 08, 2016 | 1994 Isuzu Rodeo
how do i attach the drill bit to my dremel 300
You can use a drill that fits directly ( one size) or you can use a small chuck made for the Dremel. example: http://www.homedepot.com/p/Dremel-1-32-in-Multi-Pro-Tool-Chuck-4486/100531881
Oct 21, 2014 | Tools & Hardware - Others
Cannot release tool from Dremel 300
I had a similar problem with a router, the best way to do it is to get a clamp, a strong metal c clamp, not too big but big enough to fit chuck into, line one side of clamp up with button and the other on the chuck. tighten the clamp as tight as you possibly can so it presses and holds the button in, and does not slip. Then use a wrench or whatever tool you use to undo the chuck. if this does not work, try spraying some WD40 on and leave to work for a few minutes.
Feb 21, 2014 | Dremel Tools & Hardware - Others
i can not found screw to remove chuck what can i do then
It may just be held on by the threads and locktite. I just replaced one recently and it was just like that. The spindle shaft should have two flats on it. Use a wrench (you may need to grind down the thickness of the wrench to fit the shaft. And it is most likely metric) on the shaft. If possible put a large, l shape allen wrench into the chuck and tighten it. Place the tool on the ground and keep pressure on the wrench. I will often place my foot on the wrench to hold it firmly to the ground. Using a large hammer hit the allen wrench in a counter clockwise direction. The chuck will be right hand thread. IF it had a screw that would be left hand thread. After you give the allen wrench a few good hits with the hammer it should loosen the chuck. The chuck should be 1/2"-20 thread which is common on 1/2" capacity chucks. It should be easy to find a replacement chuck. Use blue locktite and reverse the removal process to tighten the new chuck onto the tool.
Aug 23, 2012 | Hilti 284228 UH 650 Universal 1/2" Hammer...
what keyless chucks will work on my makita hammer drill will a dewalt xrp chuck work on a makita
as long as the chuck is used for a hammer drill and the thread size is exact yes it will. I believe the thread is 1/2-20 and also make sure the chuck has a hole in the center for the reversing screw to keep it from loosening up. Let me know if you need more assistance. The thread size is usually stamped on the side of the chuck. Makita sometimes used a metric thread.
Dec 31, 2011 | Makita Drills
623 people viewed this tip
Top Proxxon Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Proxxon Saw Expert? Answer questions, earn points and help others
