Tip & How-To about Orbit Irrigation 10438 High Pressure Mist Pump, 1 GPM
Very Loud pump
This pump is not recommended. It is very loud. It makes it impossible to enjoy the mist.
Orbit Irrigation 10438 High Pressure Mist Pump, 1 GPM Logo
hm2612-u is making really loud noise when running
Best solution is to take it back to the retailer for warranty repair or exchange.
Mar 03, 2013 | Holmes Homes HM2612-U Ultrasonic Comfort...
Will a cool mist be enough to properly humidify a Martha set-up?
This depends on many variables such as atmospheric humidity, casing depths, chamber size etc. Experimentation is needed to determine your personal needs and if an additional humidifier is needed or not. The recommended humidifier in conjunction with the cool mist humidifier is the Ultrasonic.
Sep 05, 2012 | 1topstore Fish
Does a cool mist is enough to provide the right humidity levels for my aquarium?
Unless you have a very large terrarium, a cool mist is usually enough to provide adequate humidity levels. If you are going for a humidifier it is recommended that you invest in a quality hydrometer to monitor the humidity levels.
Humidifiter doesn't humidify
have you checked the misting nozzle? if its clogged place it in (CLR) and let soak, I would try to run a little diluted (CLR) through the unit as well, to remove any calcium build up, that is the most common problem with most humidifiers, also check to make sure the pump is working, if not you will need to replace the pump, hope that helped
Jan 18, 2009 | Sharper Image SI491 Humidifier
788 people viewed this tip
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
