Tip & How-To about Toshiba Satellite A135-S2276 Notebook
Fix for toshiba a105 and most toshiba laptop
1) like always with anything that you do when taking your computer apart, take out the battery and unplug it (common sense)
2) Remove the plastic cover piece above the keyboard, called the "keyboard bezel". this is the piece where you can see the speakers. This page gives several pictures as to how to do this. http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-main...
**I found it a little bit difficult to get the plastic retaining clips to "pop" loose, but if you are careful, you can use a small screw driver and slowly "wiggle-pry" between the two screen mounts. this is done with the screen all the way back. you could use a paper clip with a little 1/8" bend at tip to do this also. (it is a tight working area) Once these three retaining clips have come loose the others are fairly easy to "pop" Just be patient and work it slowly. once this is bezel is off the rest is super easy.**
3) Remove the keyboard. Remove the two screws that are evident once the bezel has been removed. These hold the keyboard in place. Lift the keyboard up from the screw side and the retaining clips at the front of the keyboard will lift out. (there is no need to pry here). Once the keyboard is loose you will have to either leave it connected, just off to the side, or disconnect it from the mother board. The keyboard cable connector has a black clip along the top of it. just lift this clip up a little and the keyboard cable will slide out. (the keyboard cable does not have a fixed connector, but is just a ribbon that is held in place by the black clip along the top of the keyboard cable connector) Once you have removed it you will better understand what I mean.
4) Remove the wireless card. It is the only card visible at this point. It is connected by metal spring clips. just unclip in a similar fashion as removing ram. You do not need to disconnect the wires connected to card, just move card over to expose area below card.
5) This is where the magic is... you will see C88 clearly labeled right next the jack that the wireless card plugs into. There are two little solder squares (approx 1/16") at this location. *** At this point plug the power adapter to your computer again. ***
You will have to jump the two solder squares at label C88. I used a paper clip to do this. I used pliers to bend a 1/8" long "L" and then "scuffed" up the paperclip with the teeth of the pliers. (my first try at this did not work because the paperclip had a varnish coating on it and did not adequately conduct electricity.) Once you have your paperclip set up (or the one you used to pry the bezel with) hold it in place on these two solder contact squares and press the power button to boot your computer.
6) Your computer should boot right up and bypass the bios password, which is now reset/ erased. (You might see the Windows Error startup screen that gives you different options of start up to choose. If you disconnected your keyboard, just wait for screen to time-out and it will continue on its own) Once you have booted into windows use your mouse pad to shutdown, via start-shutdown method.
7) Disconnect your power. Reinstall your wireless card and keyboard (with screws). Don't reinstall keyboard bezel at this time. Once everything (but bezel) is reinstalled, restart the computer with battery and AC adapter connected. This should boot right into your computer without any trouble. (if for some reason it does not boot up correctly and asks for the bios password again you will be glad you left the bezel off. just redo the steps again.)
Toshiba Satellite A135-S2276 Notebook Logo
Green and blue line on tv screen an hour ago after water went on it
unplug it now wait two days, try it if its still there take it apart and clean it, power is what kills electronics not water, always unplug and remove batteries from anything electronic wet and let it dry this is always the best bet--Good Luck
Jan 28, 2013 | Computers & Internet
why does my maytag centennial agitate while it fills
The symptoms you are describing are most likely caused by a bad load sensing switch. The relay in the switch sticks and allows the washer agitate before it fills.
A simple check is to access the load sense switch and unplug the wires to it. Then check the operation. I have provided you with the instructions for accessing the load sense switch in the images below. I am also including the checks that can be made if you have a volt/ohm meter. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
Once the console is open the load sense switch is the switch that has the clear plastic hose connected to it. Remove the connector that has the violet, white and the blue with orange stripe from the switch. Then carefully plug the washer back in and start a wash cycle. If the washer does not do anything, you need to replace the load sense switch (part number W10177795). If the washer still agitates, the problem is most likely a failed timer (part number W10243947).
Image 1
Image 2
Nov 01, 2012 | Washing Machines
How do I replace my lcd on my Pavilion dv5 z-1000?
There are screws on all four corners of the plastic bezel. They're underneath the rubber / plastic nipples.
Just unscrew them and carefully peel the plastic apart from the lcd. Just use your best judgment and be brave !!
It's not hard to do. You don't need a guide or anything...just common sense.
Nov 21, 2009 | Compaq Pavilion ZT3280US Notebook
HP W22 lcd monitor turns on and off
This is a fairly common problem with lcd monitors but it can be caused by many different components.
To remove the back cover you need to insert a thin plastic strip to prise it apart. Don't use anything metal as this will damage the plastic casing. If you slide the plastic strip along the join you should be able to feel where the clips are. Once you have got 1 clip released it should be fairly easy to release the others. The clips rarely break so don't worry about them breaking. Once inside take a look at the electrolytic capacitors. These look like miniature tin cans and are normally slightly concave at the top. If any are bulging or have a brown liquid oozing from them they will need replacing. Also check all the solder joints are OK especially on the transformers. If your screen has a pinkish hue then 1 or more of the backlights is failing. The inverter detects the power difference in the backlights and shuts down as a safety precaution.
Sep 11, 2009 | HP w2207 Monitor
I need to replace the backlight on my laptop
Majority of the time it's NOT the backlight, it's the inverter. Who told you that it was the backlight specifically?
Virtually every lcd is the same procedure. Just remove the screws around the lcd, some are hidden under the rubbers, and CAREFULLY pry the plastic surrounding the lcd. It's basically common sense. Just take it apart....CAREFULLY.
That's about it, really.
May 11, 2009 | Gateway 7330GZ Notebook
2,966 people viewed this tip
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
