Tip & How-To about Canon Pixma MP500 All-In-One InkJet Printer
6B00 Error code fix
Before tearing your Canon Pixma apart try turning it upside down and shake it. I have read every one I have found approx 5 people fixing this problem and clearing this alarm error by doing this. I was one.
Canon Pixma MP500 All-In-One InkJet Printer Logo
paper not feeding in straight - pulls to one side
Kindly check if any paper piece has jammed. Kindly also check if the tray sensor is working. Most cases what I have found is paper pieces. Try turning the printer upside down and shake and then replug the connections.
Good Luck.
Feb 19, 2010 | Canon PIXMA MP170 All-In-One InkJet...
PIXMA MP600 JAMMED UP - PLEASE HELP!
Try turn it upside down and shake it - possibly it may fallout. If it is totally jammed, try using something like a crochet hook to fish it up or use a long needle nose plier to grab it and work it gently while pulling until it comes loose.
Aug 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error Code 6B00
Thank you so much.  I was getting so frustrated and finally decided to shake the printer even harder.  Absolutely AMAZING!!  Thanks again.
Sep 04, 2007 | Canon Pixma MP500 All-In-One InkJet...
False paper jam warning on Canon Pixma iP3000 printer
I have been using the Canon MP180 PIXMA for almost three years now without a hitch until I received a paper jam warning which I could not resolve. I Googled "Canon PIXMA paper jam" today and landed on this site. I turned the printer upside-down and shook vigorously. Out popped a small pebble-like bit of concrete which somehow found it's way into my printer. I guess our hardwood floor installation on the floor above had shaken up some old plaster and concrete bits that had lodged in our drop-down ceiling from our 3rd floor bathroom renovation last year and this little ****** came through an opening in our rec-room (where the computer and printer are) drop-down ceiling. A very strange sequence of events, that I would not have suspected, but happy to say that your advice here did the trick and the printer is a tough and trustworthy little printer afterall! Thank you. Dan in Canada
Sep 24, 2006 | Canon PIXMA iP3000 InkJet Photo Printer
2,151 people viewed this tip
old marine
old marine
