Tip & How-To about Nokia E50
How to free up Memory
Remember that for E50 if you ever get a page hang due to out of memory issues, you can press the "settings key" for more than 2 seconds which will open "all active appz" window. You can then use the "c" key press to close appz(in case of multi tasking)
Nokia E50 Logo
My nokia 6500s in problam hang
sir, this problem is due to virus attack, so kindly format your phone, follow the steps given below,
1. Switch off your phone...
2. Remove SIM card & memory chip...
3. Now press & hold keys - 3,*,call green) ...
4. Then without leaving these three buttons press power button...
5. Formatting task will be started...
6. Remember its a very rare trick....
Dec 28, 2010 | Nokia 6500 Slide Cellular Phone
i have a problem with panasonic kx ft938 showing "fax memory full". How can i clear it?
The memory is full of received documents due to a lack of paper, or a paper jam.
Install paper or clear the jammed paper.
or, unplug the unit for about 5 minutes.
or, to clear the RAM, try one of these procedures:
(If the first one doesn't work, try the next one)
1.
Press menu 7 dial dial dial dial * 6 start
Press up-arrow key until the display reads shipment set then press start
The display will read reset counter
Select yes or no then press start
2.
Press # 7 dial dial dial dial * 6 enter
3.
Press standby set dial dial dial dial * 6 start 9 9
On success, a long beep will be heard
4.
Press menu 7 monitor monitor monitor monitor * 6 start
Parameter 65 for memory collation should be set to invalid to maximize the memory page rating
Nov 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
HOW TO REPROGRAM?
For you to reprogram your nokia phone, just follow this steps;
1. Install Nokia PC Suite for your brand at http://www.nokiausa.com/ on your computer.
2. Check for the available updates for your brand, if you have available updates for your phone brand. Then install on your computer.
3. Connect the phone to your pc via USB and update.
This action would utomatically reprogram your cell.
Hope this helped.
Regard
Sep 27, 2009 | Nokia E50 Cellular Phone
my htc 3400 gives lom memory error and hangs
clear out your cache and temp files in the options screen. Do you have a micro sd card installed? If there isn't enough memory to run some applications, it will draw off your micro sd card
Dec 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
1,251 people viewed this tip
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
