Tip & How-To about Motorola Mobility V276 Cellular Phone
Reset lost unlock code for Locked Application on a V276
This only works if you have locked an application on your phone. I won't work if your phone is completely locked out because you can't access the menu's on your phone. Of course this hack makes it possible for someone to unlock your "Partially" locked phone.
WARNING.....This will reset your menus back to default but it didn't reset my shortcuts. My "Home screen" was reset to the default picture. Didn't change my call lists, contacts, or text messages. I didn't see other changes but there could be more....WARNING
Reset your "Partially" Phone,
Press Menu
scroll to Initial Settings (or press 5)
Scroll to Master Reset and select
you will see a "Enter Security Code" screen
enter 8 zeros like this 00000000 and press ok
Answer "yes" to reset the phone and your applications will be unlocked.
Use "Master Clear" to clear all the personal info off your phone, contacts recent calls, Pictures, everything
Motorola Mobility V276 Cellular Phone Logo
locked by another application cannot access contact now. is what im getting when trying to see phonebook. any ideas whats going on?
hi i have sony ericsson C903 and this ''locked by another application cannot access contact now'' happens after i finish skype application. to be able to acces contacts again i have to take the battery out and sim as well and wait 30 sec before putting it back. annoying
Aug 01, 2010 | Sony Ericsson W850i Cellular Phone
Motorola v557 applications locked
YOUR CELLULAR PROVIDER CAN RESET YOUR CODE AT ONE OF THEIR SERVICE OUTLETS. SEE IF YOUR RAZOR HAS A SIM CARD LIKE MINE. POWER OFF PHONE AND REMOVE IT CAREFULLY AND REPLACE IT. SOME SIM CARDS (DEPENDING ON THE PROVIDER WILL RESET TO FACTORY SETTINGS.) gOOD LUCK
Aug 11, 2007 | Motorola Mobility V557 Cellular Phone
how to unlock cell phone
lock application
Lock phone applications:
Find it: s >wSettings > Security
> Lock Application
When prompted, enter the unlock code and
press Ok. Then scroll to the application you
wish to lock and press Change.
change unlock and security codes
> New Passwords > Unlock Code or Security Code
control access to location function
Set up a location code to control access to
the Location function (see “AGPS & your
location” on page 59):
> New Passwords > Location Code
Apr 25, 2010 | Motorola Mobility KRZR K1 Cellular Phone
6230i application cant access the phone memory
First you have to move your information to memory card.You can order passphrase to the card memory chip menu => memory card =>Options => set password. Good Luck!
Aug 13, 2007 | Nokia 6230
Motorola v557 applications locked!
try 0000
if not
unplug the battery
& plug in the battery again
try 0000
Aug 12, 2007 | Motorola Mobility V557 Cellular Phone
2,343 people viewed this tip
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
