Tip & How-To about Pool & Spa
How To Backwash and Clean Above Ground Sand Pool Filter
This video will show you how to use the different settings to backwash and clean your above ground pool sand filter.
Pool & Spa Logo
Using a swimming pool filter system to 'vacuum' the pool floor
i am assumming that you have a sand filter,to clean your filter, 1st put it on backwash and watch the little glass bowl till it run clear,45 sec. or so then turn off power, turn valve to rinse, turn power on. watch little bowl till it runs runs clear 30 sec. or so.to vaccam turn handle to waste turn power on. hope this helps
Aug 08, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
sand in backwash
You need to replace the seal in the head unit of the filter.. The sand should be replaced every three years or buy a cleaning solution.
Jun 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
my pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
May 13, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
multi-valves on hayward sand filter mixed up
Key Cover Assy needs new spider gasket. If it is a newer model the gasket is made into the key cover and it will have to be replaced
Apr 27, 2009 | Hayward Pro Series 18" Above Ground Pool...
893 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
