Tip & How-To about Razor E300 Scooter
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
Razor E300 Scooter Logo
scooter has new batteries and still barely runs up slight hills its the E 200 scooter
On the Razor E200 check the chain is fully tightened & lubricated & you will be amazed what incorrect tyre pressures will do (36psi) to the power of the scooter.
Jun 17, 2011 | Razor E100 Electric Scooter
re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Jun 28, 2010 | Razor E100, E125 & E200 Electric Scooter...
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
1,055 people viewed this tip
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
