Tip & How-To about Datel Action Replay for Nintendo DS
Making sure the Action Replay turns on every time
Before you start your game(with the AR of course), make sure that everything is right:
  • Is the Action Replay all the way in?
  • Is the game in the action replay straight?
  • Did you charge the DS with the AR in it? (mine works when I do that)
If all of this is right and it still doesn't work...
take the AR out of the DS and the game out of the AR, put it back together and restart the DS.
hope this helps you peoples=^.^=
Datel Action Replay for Nintendo DS Logo
My action replay doesn't work with the game Animal crossing Wild
There are two possible reasons why it won't work 1. You used may have used to many cheats at once which overloaded the Action Replay. 2. I have noticed that sometimes there are a few bad codes that cause the game to mess up and freeze when the Action Replay is used.
Happy Fixing :u)
Oct 19, 2009 | Datel Action Replay for Nintendo DS
AR says 'insert game cart', when a game is already inserted...
I have this problem too and I am trying to find a better way to fix this, but here's a simple solution so far:
1. Put in your AR and go the the code menu for you game.
2. Select any codes you want to use.
3. Take out the AR and insert the game.
4. Press the START icon that should now be showing.
NOTE: If the game being played is reset or you used Soft Reset the codes turn off.
May 30, 2009 | Datel Action Replay for Nintendo DS
Action replay for NDS and Pokemon Diamond
You have a bad cheat or a wrong cheat enabled. That is why it's not working. Just disable that cheat and it should work fine.
Apr 05, 2009 | Datel Action Replay for Nintendo DS
MY ACTION REPLAY NOT WORKING!!!!!!!!!
That has happened to me. Actually, all the time. There are many things you need right for it to work every time:
hope this helps=^.^=
Mar 01, 2009 | Datel Action Replay for Nintendo DS
Action Replay Problem
The problem is that the games or the ds action replay game slot is unfunctional. If it is the AR, just start up the action replay and eject it. Then put the game in, and start playing. To enter codes, leave the AR in and enter the codes. after you enter codes, the AR will save atomaticly.
Oct 20, 2008 | Nintendo DS Lite Console
682 people viewed this tip
Top Datel Video Game Consoles & Games Experts
Martin Murray
Raj Patel
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
