Tip & How-To about i-mate Jama 101 Smartphone
Set-up your I-mate Jama 101 into a Wireless Modem
Your i-mate™ JAMA 101 can be configured to act as a modem for your PC, allowing you to have a connection to the internet for your PC while you are out of the office or away from home. Your PC can be connected to your i-mate using Bluetooth® or a USB cable.
Although setting the device up for Internet sharing the first time may take some minutes, you only need to do these actions once per PC. Subsequent connections are quick and are explained at the end of each configuration.
Before you start, you must ensure ActiveSync 4.2 or later version is installed on your PC. You can find this program on the Getting Started CD that came with your device. You cannot run this function with earlier versions of ActiveSync. These instructions show how to set up your PC for connection over GPRS, please contact the customer support team if you wish to connect over a circuit switched connection. If you are running Windows Vista on your computer, you do not need to install Activesync. Windows Mobile Device Center software comes pre-installed with your operating system.
Getting Started
1. On your i-mate go to Start > Programs > Internet Sharing
2. You will be presented with the main screen of the Internet Sharing program
You now need to define the Web connection that your device will use to access the internet. If you have already defined an internet access connection in your device, you may select it from the dropdown menu in the ‘Network Connection’ list, and you are ready to connect to the internet. You can go straight to the section ‘Connecting over USB’ or ‘Connecting over Bluetooth’. If you have not yet defined an internet connection, you must define it now.
3. To set up the connection from inside Internet Sharing, go to Menu > Connection Settings
If your cellular subscription includes a GPRS subscription to the internet, then choose the GPRS option. In the bottom right, click “Next”.
4. Now fill in the details for your cellular provider’s access to the internet. You should contact your cellular provider for these details.
For the description field, you can type in any name you wish. For the “Connects To” field, choose “The Internet”. The “Access Point Name” field must be filled in with the details provided by your network operator.
Also enter the user name and password provided by your mobile operator, and any other details they provide, such as Primary DNS, Secondary DNS and IP address. If your mobile operator does not provide these to you, then leave the fields blank.
Once complete, press Done, then Done on the next page, and then Done on the next page to return you to the Internet Sharing application.
i-mate Jama 101 Smartphone Logo
i-mate jama 101 battery charging -internet connection
hi , i hava i-mate jama 101 , when it off because of the low power ,i can't charge it only if i charge the battery with a universal charger???
Apr 09, 2010 | i-mate Jama 101 Smartphone
How to format i-mate jama p30 and i want pc suit for it
hello .. i have got imate jama p30 .. im tryin to connect the internet but its sayin like the adress is not valid .. wat wud be the problem can someone help me out..
Apr 06, 2010 | i-mate Jama 101 Smartphone
i need the gprs setting for my i-mate jama 101 mobile phone
how can connect to internet using my jama 101 phone
Mar 14, 2010 | i-mate Jama 101 Smartphone
internet connection from imate to labtop
hi thanks for using fixya!
What is the model of your Imate?
Here some tips:
Mar 30, 2009 | i-mate JAM Pocket PC
1,610 people viewed this tip
Top i-mate Cell Phones Experts
270rexton
270rexton
Jax Planet
Jax Planet
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
