Tip & How-To about Nokia N81 Smartphone
Sound Problem
Dear sir,
i have nokian81 8gb phone and i have been change my housing but after changing my housing the phone sound is not good even i can't hear the ring tone pls help me out this problem.thank you
Nokia N81 Smartphone Logo
can't hear sound on nokia 2626. In the scree there is car sing. how to solve this problem sir/Madam.
THE ONLY THING IS TO CHANGE THE CHARGING INTERFACE.(Charging socket).I've tested 100%solved.Good luck thanks for visiting Fixya.
Jul 22, 2011 | Nokia 2626 Mobile Phone
Sigmatel mobile flight mode problem
i have a mobile sigmatel s90 . Unfortunately i have enter into setting and change to flight mode then my phone can not open even menu option also not open. so sir
Sep 25, 2008 | Samsung SCH-U470 Juke Cellular Phone
Cobra PR 260
Dear sir,
Try to operate in channel 1~7 , keep the maximum range extender button pressed for 5 seconds u will hear 2 beeps sounds. If it works Ok or else u need to change your Radio antennae
Sep 14, 2008 | Cobra PR 260-2WXVP Two Way Radio
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS GMC186@BELLSOUTH.NET
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
no tones on nokia 6131
check your buzzer if it was still ok, using tester set it in X1 if the buzzer creates sratch sound if you connect your testprove in the terminals of your buzzer it was ok but if you cant hear any sound, it was defective, so you have to replace it. good lack........
Jul 18, 2008 | Nokia 6131 Cellular Phone
1,608 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
