Tip & How-To about Sony KDF-E60A20 60 in. LCD HDTV
Fan cleaning on sony LCD
Cleaning of air vents and fan is very important in sony LCD tv.Have found buildup of lint and dust reduces air flow which can cause shutdown due to overheating. This is a big problem in sports bars.
Sony KDF-E60A20 60 in. LCD HDTV Logo
my computer is automatic shutdown
Have you cleaned the fan, vents, heatsink? If a laptop overheats, due to dust, poor ventilation, blocked vents, it will shut down to prevent damage to vital components. Clean, improve air flow through the bottom and out the vents. Never use on soft surfaces that can block air flow. Contrary to the name, Laptop, it's not good to use on your lap. Go figure? If the Laptop is Clean and air flow isn't a problem, open Power Settings in Control Panel,and change Advanced Power settings to Sleep/Hibernate to Never, set to High Performance, unplug and remove battery when not in use. If you use mostly on AC remove battery.
Sep 24, 2013 | Computers & Internet
My fan keeps speeding up , then it slow downs what causes this? an how can I fix this?
which fan is doing this? Mostly likely it is caused by dust or overheating. Use a can of compressed air found at any electronics store to clean the dust out from inside the computer. If that doesn't solve the problem I would next try replacing the fan.
thank you,
Lee
Sep 21, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
dryer has to run two or three times to dry clothes seem to be hot enought. any suggestions
Check your lint filter. Keep it clean every time you dry clothes. If it is clean ther is a good chance the hose that carries the hot air and lint from machine to the outside of the building. Also the lint fan may be burned ot. YOu should feel air blowing when you pull the lint filter out of the machine. If not the motor is shot.
Sep 24, 2010 | Dryers
auto shut down due over heat
Very Very Carefully disassemble the laptop, and clean out the processor fan, and any other "vent" looking things. Lots of times hair (especially pet), dust and other pollutants will clog these, or they may stop working all together, and need replaced.
Nov 19, 2009 | Sony VAIO GRZ660 Notebook
Heater works but clothes do not dry. Very little air flow from vent
Sounds as if there is something (lint buildup maybe) that is blocking the air flow inside this machine. You need to remove the top and front of this machine so you can view in internal working parts. Clean it out the best you can and also remove the rear cover and check where the fan blade is located and this general area. I have seen rats nests built inside the tubes that will block air flow and create a fire hazard.
Oct 11, 2009 | Roper REX4634KQ Electric Dryer
2,744 people viewed this tip
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
