Tip & How-To about Microsoft Windows Media Player
Can not play all the file
WINDOWS MEDIA PLAYER.or wmp.
Windows Media Player (abbreviated WMP) is a digital media player and media library application developed by Microsoft that is used for playing audio, video and viewing images on personal computers running the Microsoft Windows operating system, as well as on Pocket PC and Windows Mobile-based devices. Editions of Windows Media Player were also released for Mac OS, Mac OS X and Solaris but development of these has since been discontinued..
although it does not support such codec..
it can play wmv.exe or avi but not flv or such other it does not support these codecs.
Codecs in Windows Media Player 10 loadTOCNode(2, 'moreinformation'); Collapse this tableExpand this table Codec Company Description Windows Media Audio Microsoft This codec is used to encode complex audio files, such as music files. The most recent versions of this codec are the Windows Media Audio 9 codec and the Windows Media Audio 9.1 codec. Windows Media Audio Professional Microsoft This codec is used to encode complex audio files, such as music files. This codec supports multichannel encoding and 24-bit encoding. Two versions of this codec are the Windows Media Audio 9 Professional codec and the Windows Media Audio 9.1 Professional codec. Windows Media Audio 9 Lossless Microsoft This codec is used for lossless encoding of audio files. Two versions of this codec are the Windows Media Audio 9 Lossless codec, and the Windows Media Audio 9.1 Lossless codec. Windows Media Audio 9 Voice Microsoft This codec is optimized for encoding the human voice at a high compression ratio. This codec is the preferred codec for encoding data streams that primarily consist of spoken words. For content that is a mixture of music and speech, this codec yields a very high quality audio file. Windows Media Video 9 Microsoft This codec is used to encode complex video files, such as movie files. The Windows Media Video 9 Advanced Profile Video codec is a version of this codec. The Windows Media Video 9 Advanced Profile Video codec is incorporated into advanced encoding features such as interlaced encoding. Windows Media Video 9 Screen Microsoft This codec is optimized for encoding sequential screen shots. For example, this codec is frequently used to record screen shots of monitor images of software applications. The monitor images are later used for software training. Windows Media Video 9 Image Microsoft This codec is used to convert bitmap images with the deformation information into a compressed video. Two versions of this codec are the Windows Media Video 9 Image codec, and the Windows Media Video 9 Image v2 codec.VIDEO CODECS
Video codecs in Windows XP SP2 loadTOCNode(2, 'moreinformation'); Collapse this tableExpand this table Codec Company Cinepak Radius (Supermac/Compression Technologies Inc.) DV Microsoft Indeo Video 3.2 Intel Indeo Video 4.5 Intel Indeo Video 5.10 Intel Indeo iYUV R2 Intel RAW YVU9 Video Driver Intel MJPEG Microsoft MPEG-1 Video Decoder Microsoft Microsoft ISO MPEG-4 V1 Decoder Microsoft Microsoft ISO MPEG-4 V1.1 Decoder Microsoft Microsoft CRAM Microsoft Microsoft MPEG-4 (V1) Microsoft Microsoft MPEG-4 (V2) Microsoft Microsoft MPEG-4 (V3) Microsoft Microsoft RLE Microsoft Windows Media Screen (V7) Microsoft Windows Media Screen (V9) Microsoft Windows Media Video Standard (V7) Microsoft Windows Media Video Standard (V8) Microsoft Windows Media Video Standard (V9) Microsoft Windows Media Video V9 Image Microsoft...
SO IT IS NOT VALID TO ALL CODECS..
Microsoft Windows Media Player Logo
how can you listen to music
First, you will have to transfer the music to the mp3 player. You can transfer music and pictures to your player using Windows Media Player. YOu can download it from here:
http://windows.microsoft.com/en-US/windows/products/windows-media-player
Once you have installed WMP, reboot and plug your mp3 player. By default, Windows Media Player automatically loads all the music and picture files stored in your My Music and My Pictures folders into the library. If you add new files to these folders, they will also be automatically added to the library. Then you will have to synchronize your mp3s player with WMP.
You can sync your music and pictures to your player using Windows Media Player. Simply connect your player to your computer using the supplied USB cable, set up sync, and you will be ready to sync your media library to the player. When you connect your player to the computer for the first time, Windows Media Player automatically selects the sync method (automatic or manual) that works best for your player. Automatic: If your player has sufficient storage space (at least 4GB of free space) and your entire media library can fit on your player, your entire media library will be automatically copied to your player as soon as you connect it to your computer. Manual: If your entire media library cannot fit on the player, then you will be prompted to manually select specific files or playlists that you want to transfer to your player.
Once you have transfer the music you want-unplug the player from the computer and that's it. If you have more doubts, you can download the manual from here:
http://download.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
Feb 10, 2011 | Philips GOGEAR SA6045 MP3 Player
how doi get the files to go to my windos media player library?
GO TO THE FILE WERE YOUR E-MUSIC IS DOWN LOADED TO AND EACH SONG AND LAUNCH IT FROM THERE MAKE SURE YOUR WINDOWS MEDIA PLAYER IS SET AS YOUR DEFAULT PLAYER YOU CAN DO THAT BY RIGHT CLICKING ON EACH SONG AND CHECKING IT AFTER YOU LAUNCH THE SONG FROM THERE IT SHOULD PUT THAT SONG IN YOUR WMP LIBRARY AND ALSO USE WMP TO PLAY THE SONG YOU DONT HAVE TO PLAY THE FULL SONG JUST THE BEGINING OF IT,IF THAT DOES'NT WORK THEN CHECK YOUR WMP SETTING TO MAKE SURE THAT THE SONGS THAT YOU LAUNCH WITH WMP ARE AUTO ADDED TO YOUR LIBRARY
Mar 14, 2009 | Audio Players & Recorders
Help downloading onto computer
This is an easy process, just connect a commercial USB cable that is compatible with your device or the USB cable that came with it to ur computer. go to my computer and double click on the MP3 player drive icon. Navigate to the MP3 drive folder where ur music files are stored, launch windows media player( WMP 11 is AVAILABLE AT MICROSOFT.COM/DOWNLOADS) or if you already have windows media player 11, that's good. click on tools in WMP and select OPTIONS, click on LIBRARY and click on MONITOR FOLDERS. select ADD to add your MP3 player drive to the list of monitored folders, after you finish adding the MP3 player to the list, click on OK and windows will search the drive for music and video files and add them to your WMP Library.
Dec 14, 2008 | SanDisk Sansa Fuze MP3 Player
windows media player not working
Very the file you are trying to play is still there , if it is then create a new play list by allowing WMP to scan your system for playable media. If this fails or the above aint the latter then i'd suggest you uninstall WMP and reinstall it. WMP is in the control panel / add or remove components / Windows Components. You can also log in to microsoft web site and download the latese WMP and install it .
Jul 09, 2008 | Microsoft Windows XP Home Edition
Windows media player can't play .wmv files
  • Firstly a UPS is an abbreviation for Uninterrupted Power Supply - meaning emergency backup power in the event of a mains power failure. This is not a type of PC.
  • Secondly - Windows media player does not support every type of movie format, as Microsoft Update it from time to time, some formats will still not be supported, these are known as codecs.
  • Thirdly, codecs to support your particular format can usually be downloaded and added to Windows Media Player, however i can not think of any reason .wmv files are not supported by Windows Media Player.
You could try re-downloading the latest version of Windows Media Player from one of the links provided below.
WMP 11 will support the latest codecs, but if for some reason you find yourself needing the older version, use WMP 10.
You will most likely have to remove your current version of WMP, and you can do this by using Windows Add/Remove programs.
  1. Click on the Start menu button ( bottom left corner of your screen. )
  2. Click on Control Panel.
  3. Click on Add or Remove Programs.
  4. Click on Windows Media Player in the list.
  5. Click Remove ( right hand side of the listing )
Microsoft WMP 11 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Microsoft WMP 10 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
WMV 11 is available by clicking on this link:
http://filehippo.com/download_windows_media_player/
Feb 05, 2008 | Computers & Internet
1,286 people viewed this tip
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
