Tip & How-To about Peg Perego Venezia Single MT Blu Moon Stroller
Front wheels not good for uneven ground
I have trouble with this stroller when pushing it over uneven territory like grass or a gravel path. What I have found helps is to lock the front wheels in place (the back wheels would normally already be locked) while pushing it on the uneven ground. You have to steer just by pushing it but it makes the overall pushing easier. When I am on even ground, like a sidewalk or at the mall, I keep the front wheels unlocked.
Peg Perego Venezia Single MT Blu Moon Stroller Logo
the mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Good Afternoon, My question is this. I'm intersted in buying a Eddie Bauer Tandem Double Stroller price at Sears is 279.99 colour Dark blue. I have a one year old and I'm due to have my third child in March. Having said that I wanted to know if an infant car seat would fit in the rear seat of the double stroller...second part to my question is I have a Quinny Freestyle stroller given to me as a shower gift in 2008 and wolud the infant car seat be compatable with the Eddie Bauer Tandem Double Stroller. Thanks Lacey
My experience with tandem strollers is that they are difficult to manoeuvre in cities (over kerbs, grass, gravel, etc.) and hard to turn. I also found that the infant car seat into the stroller trick is short lived, and you'll need the stroller for a long time after you need that.
My recommendation would be to buy a good side by side double with larger jogging type wheels instead. Tike Tech makes a great one that folds easily and is a lot easier to push.
Nov 25, 2009 | Eddie Bauer All Terrain Tandem Double...
how do i fold my icco?
First put the 2 front wheels to face inward then then press the wheel locks down (found on front of the wheels). While standing at the back of the stroller (pushing position), there is this sort of a black plastic tube located on the left side of the pushing bar. Grasp this black tube and push it upward and while doing this push the pushbar downward. The stroller should fold down as you do this.
Dec 15, 2008 | Hauck I'coo Pico 4 Standard Stroller
822 people viewed this tip
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
