Tip & How-To about Fisher Price Comfort-Lite Tandem LX 13156 Twin Seat Stroller
WHEELS
THE WHEELS Y7OU SHOULD PUT LUBRICANTS SO THAT IT WILL NOT STOCK UP.
Fisher Price Comfort-Lite Tandem LX 13156 Twin Seat Stroller Logo
how to change rear differential in a Ford1994 crown victoria
sounds like a lack of lubrication these rearends used specialized lubricants and most oil change shops do not want to stock a lot of lubricants
Aug 28, 2014 | 1994 Ford Crown Victoria
GTH2654T WILL NOT DRIVE R BACK UP
did you have the rear wheels off or one of the rear wheels off to do something?...sounds like one of the square keys that drive the wheels is missing. I did it myself once.pulled and wheel and forgot to put it back in. same response. check both rear wheels to make sure the key in still in both slots of the wheel. its a 2 or 3 inch piece of 1/4 x 1/4 inch square stock. if you lost it you can buy square stock 1/4 inch at a good hardware store.
May 10, 2014 | Husqvarna Garden
finding a non-toxic lubricant
It would be fine to use a "toxic" lubricant as long as it wasn't oil based. Also, run the washer at least three to four times empty before using it on dishes.
Feb 23, 2014 | GE Nautilus 24" Built-in Dishwasher
wheels rattle when changed from stock to a GM wheel. what size spacer?
Put the stock wheels back on or find some jeep compatible wheels you like. You might have a bolt hole pattern problem.
Aug 21, 2012 | 1995 Jeep Grand Cherokee
I want to mount 18 Inch Chryser 300 Wheels on a base 2.7 Magnum
More than likely you'll need to install some spacers to prevent the rubbing...
Aug 25, 2008 | 2006 Dodge Magnum
514 people viewed this tip
Top Fisher Price Baby Gear Experts
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
