Info on replacing polaroid caps
prowler21
By Apprentice prowler21
Rank: Apprentice
Rating: 100%, 6 votes
posted on Mar 22, 2009
Very Helpful
All Polaroid flat panel
I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After removing the to caps I noticed they were not 10v but 35v. I replaced with the same size and TV works fine! It is not just the FLM-3734B model that has this problem. It is all polaroid flat tv's. I do not believe increasing from a 10v cap to a 25 or 30v cap will increase reliability. I used same size & voltage but increased operating temperture range from 105C - 120C.These high temp caps can be perchased at Newark.com I hope this info helps, any questions send e-mail to prowler21@verizon.net
Was this helpful?
Yes
No
5 people thought this was helpful
Comment #1
posted on Jun 02, 2009
gjsbooks
By Apprentice gjsbooks
Rank: Apprentice
Rating: 0%, 0 votes
the capacitor problem is not the only one. if the capacitors are bulged, they I'd recommend trying the fix-- it's not too difficult. The hardest part is doing the de-soldering and re-soldering. Just go slow.
I replaced them both and I still have the same problem-- so there is another issue that causes this TV to not work.
I'm going to take the entire thing apart and see if I can find anything wrong with any other board :(
If I find a solution, I'll post it here!
Can you Help with these Flat Panel Televisions problems?
Polaroid FLM-3734B 37 in. HDTV LCD...
705537401AX1H ineed a screen for the polarid same one with...
the tv just turns itself off and red light blinks... then...
I have a 27" Polaroid LCD TV and all of a sudden when...
no sound, picture fine.
switches on but nothing on the screen or no sounds
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
