Tip & How-To about Intel Math Kernel Library 5.2 Full Version for PC
How to fix windows xp look that shoud egzist in my sys. anymore,it only apears in wind. classic window.
Intel Math Kernel Library 5.2 Full Version for PC Logo
system32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Dell Inspiron 1000 PC Notebook
No one should be using Win XP anymore. Upgrade to Win 7.
Dec 23, 2017 | Dell Inspiron 1000 Notebook
how to fix windows xp look that shoud egzist in my sys. anymore,it only can wiew in classic windows mode
You want XP to look like when you first got it and not in classic mode, am I correct? If that is the case, do the following:
  • Right click on your desktop and select Properties
  • Go to Themes tab and select Windows XP and press Enter
That should bring you back your screen. If that did not help, then do the following:
  • Right click on my computer and select Properties
  • Click the Advanced tab
  • Select Visual Effects tab
  • Chose either Adjust for best appearance or you can let Windows decide what's best for your system.
Finally, if that does not work go into Control Panel --> select Administrative Tools --> Services. Look for Themes in Services to make sure that is is both set to Automatic and that the services is started.
Mar 20, 2009 | Microsoft Computers & Internet
Fujitsu amilo d1845, Windows xp start up problems
Steven,
it could be a heat realted, can you get to the cpu cooler? most laptops i have worked on this is accessible by lifting the keyboard.
Give it a blow out with a compressed air can and see if that works, if not try lifting the cpu cooler and cleaning off old thermal paste and reapplying new.
Regards
Nick
Oct 25, 2008 | Computers & Internet
wants a window xp style in display panel
Right click your desktop and point to properties and then select themes. You can choose what is the best style you want.
Jun 09, 2008 | Microsoft Windows XP Professional for PC
2,056 people viewed this tip
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
