Tip & How-To about Humco Alcohol Denat Completely Denatured 16oz
How to get rid of ants.
To get rid of ants, pour some denatured alcohol into their holes. It will work like a charm!
Humco Alcohol Denat Completely Denatured 16oz Logo
Model i9900 - All colors are not printing even though all colors are inserted and good.
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
Mar 29, 2010 | Canon Office Equipment & Supplies
My canon inkjet mp360 series will only print in colour. The black does not work. They are both new cartridges
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Mar 29, 2010 | Canon MultiPASS MP360 All-In-One InkJet...
won't print black ink
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Mar 25, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma ip1500 printer
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Try this solution to reset the ink tank , it should work for most pixmas and several other Canon printers.
http://www.fixya.com/support/t538192-waste_ink_almost_full
Mar 25, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
do not printe and see the text pinte
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Mar 22, 2010 | Canon MX300 Office All-In-One Printer
418 people viewed this tip
Top Humco Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Humco Health and Beauty Expert? Answer questions, earn points and help others
