Tip & How-To about Tannoy Mercury MX4-M Main / Stereo Speaker
Biwiring
Use biwiring --- improves the sound quality a lot..esp the bass effect
Tannoy Mercury MX4-M Main / Stereo Speaker Logo
sound bass
Laptops are notorious for poor sound performance, the issue is the speakers used on any laptop are not big enough to convey the deep rich bass some users require.
A workaround to this is to buy a good set of headphones when utilizing the sound system on a laptop.
Otherwise you need a better quality laptop; Some are made with premium sound speakers but again they too are limited due to the speaker sizes used in laptops. Not to mention the cost of getting one of these types of laptops.
Sep 25, 2013 | Toshiba Satellite Computers & Internet
I have 2 KEF Q35 speakers, i have them wired up as normal on the outside ports, but there are another set of wiring ports labelled HF (one positive one negative) what are these for? please help!!
These are quite common, and are just separate connection for each speaker in the enclosure. Just bridge the connections red to red and black to black with cable (use something like 5amp house wiring cable) and then connect your cable from your amplifier to one of the "ports" See http://www.brilliancehifi.co.uk/how-to-bi-wire-speakers.htm As you can see you could "biwire" if you wanted go further and improve the sound quality
Nov 24, 2009 | KEF Audio Q35 Speaker
bass sounds muddy and volume is minimum.
Hello mercedesman4,
Your setup sounds great. I had to settle for Blaupunkt in my Mercedes.
It sounds like the culprit is your enclosure. It's possible that by tweaking the settings, you could improve the sound somewhat, but having been used to the sound of a sealed enclosure, maybe not. Sealed enclosures tend to produce tighter, more accurate bass and have a flatter frequency response curve. They are also generally the enclosure of choice when looking for a SQ (sound quality) oriented setup.
Ported enclosures will produce louder bass than sealed enclosures, and maybe that's why some audio guys push them. They also allow the speaker to operate more efficiently, so you need less amp power for a given volume. Higher tuning on a ported box will get louder, but at the expense of sound quality. Lower tuning will still get louder than a sealed box, and the sound quality will be better than a box tuned higher, but still not as good as sealed. That's what I meant about tweaking the settings. You may see some improvement by setting the crossover lower, decreasing bass boost, or by turning the subsonic filter on/off. I'm no audiophile, but personally I've never been able to stand the sound of a ported enclosure, however it was tuned. Sealed just sounds better.
Hope this helps.
Mar 30, 2009 | Car Audio & Video
Vizio 42'' TV Sounds like it is in a metal tube.
The volume was up on the TV, but down on the cable box remote. By raising both volumes the sound quality improved dramatically.
Nov 23, 2008 | Vizio L32 32 in. LCD HDTV
bi amp
Hi there, I am assuming that you wish to BiWire the speakers. This involves removing the link on the back of the speaker box and running additional speaker leads for the HF drivers, as well as cable for the LF drivers. BiWiring allows you to use different cable that has been designed with high frequency signal path in mind. It may feature things like silver plating, low capacitance, or as many other "features" as can be tagged to the cable to sell it as a specialist HF conductor. The benefits may be subtle, and not be that noticeable. It does isolate the potential voltage drop along the length of the cable associated with LF energy away from the HF side of the speaker system, and take advantage of Skin Effect, where HF energy tends to travel on the surface of the conductor.
Using a single cable for each channel and leaving the links fitted is perfectly fine and will operate no worries. You could go and spend the extra cash and upgrade your cables to HF and LF BiWire.... the sky is the limit on cost here for what may not be a noticeable difference:)
BiAmping in a different story where much more performance increase is achieved by using a separate channel to amplify HF and LF signals. But you need an amp that has a built HF and LF outputs for each channel to do this. They exists but I have not seen any surround amps that have it.
Go with decent quality realistically priced speaker cable first, then add your HF BiWire to the rig if you are looking for that little bit extra from it:) Good luck, and happy listening.
regards
Graeme
Feb 28, 2008 | Monitor Audio Bronze B4 Speaker
1,044 people viewed this tip
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Trippy Tripp
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
