Tip & How-To about Sony Camcorder/Audio/Video 900MHz Wireless Headphone Sys Headphones
Sony wireless headphones
I had a problem with too must static noise lots of hiss, i moved the headphone amp away from my x box as that was makin the problem. NOTE that ur tv can make a problem too or pc wot ever but problem shoved.
Sony Camcorder/Audio/Video 900MHz Wireless Headphone Sys Headphones Logo
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
Sony wireless headphones have static...why?
There are ways to fix interference, but first you have to find where it is coming from. First, switch off appliances one at time, fridge, freezer, furnace, AC, anything with a motor in it.
then start with wifi, turn your router off, and then any audio units, and set top boxes not involved in the test. Disconnect speaker wires one at a time.
One of these things is miraculously going to make the noise stop. Then you find out why? It is often screening wires badly connected. Any wires involved with audio and power should be kept apart, especially ANYTHING to do with the wireless headphone transmitter.
Google Ferrite rings. Also use good quality, screened audio, and speaker leads.
ferrite rings audio Google Search
Feb 28, 2017 | Sony Audio Players & Recorders
When i turn on my yamaha f20 guitar amp, it produces a hissing/ static radio sound. Is it the power capacitor or something else?
Possibly interference from another electrical source. This can be compounded by high gain or the use of a distortion pedal. Try moving the amp to the middle of the room or away from things like appliances, lighting dimmer switches computer, tv etc.
Hope this helps.
Apr 05, 2011 | Audio Players & Recorders
Brookstone wireless headphones have static along w/ tv sound
Well I just plugged into the cable box and that worked. On my old tv as well as my newer one the only audio out was an optical I had bought an optical splitter (one input for my sound bar and the other one to the optical to Rca) and an optical to rca for the headphones. This allowed me to use the headphones on all things going through the tv. For some strange reason it no longer works that way (just got my new tv this week). I bought all pieces on Amazon for a nominal cost. I'm going to doublecheck all connections again tomorrow.
Jul 12, 2010 | Brookstone Surround Sound Earbuds...
Sanyo TV DS32224
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Mar 23, 2006 | Sanyo DS27910 27" TV
1,480 people viewed this tip
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
