Tip & How-To about Neff B1476 Pyrolytic Stainless Steel Electric Single Oven
If the door is locked shut after self cleaning
- Let the over cool down - unplug at the mains and leave it unplugged for a good minute or so - reset the clock The door may well open now. It happened to me today !
Neff B1476 Pyrolytic Stainless Steel Electric Single Oven Logo
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
No power on stove after using self clean oven door is locked and cant be open is there a braker swith somewhere
A self cleaning oven that won't open after the self cleaning cycle is usually the oven has not had time to cool down from the high temperatures of cleaning. You should wait at least an hour to open it. You can also try to unplug the unit or turn of the breaker to the over for at least five minutes. You will then have to reset the clock and then try to move the door lock. If that does not work, you can set the self clean cycle again for but only allow it to work for 15 minutes, then cancel the cycle and let the oven cool and then again try to move the door lock or open the door If that does not work, then the lock will have to be accessed and moved manually to open the door
Some ovens need the door to be manually unlatched before the controls are set to the off position before they can be unlocked.
Mar 07, 2011 | KitchenAid Ovens
door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
Feb 28, 2011 | Viking Ovens
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
722 people viewed this tip
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
