FORGET ALL THINGS THAT YOU WERE PREVIOSLY TRYING TO DO!!!
No #pwd#/send thingy, no bying the unlocker from the internet,no nothing!
FOR ALL TYPES OF SAMSUNG MOBILES!
Easy way to unlock your phone,to make that security/private password ''go away''
THIS IS NOT A JOKE!
Aldough you should know the procedure of doing it,and how to protect yourself from losing valuable memory parts (pics,vids,documents,mesages,set-ups,themes,etc...)
First of all,your phone should be ''Samsung'' brand.If not, then I am not responsible If something else hapened,and not guilty 'cause you didn't read ''FOR SAMSUNG ONLY''.
Ok,now if you want to do this right, you should save all memory you do not want to lose to any other memory than the phone memory.That includes memory cars,SIM cards, and if needed, send it to computer via infrared/bluetooth, or to another mobile,just in case you can't do all prev things,and you need those files after the procedure (simply file transfer it back)
Ok,now that you have done all of these things in proper order,succesfully saving all the things you need,you should do the folowing:
Depending of what you need, choose the folowing.You will enter the sequence EXACTLY as I typed it here, and with #/* signs also.You will enter them the same way you are entering a number to make a call.
Before you do this, I strongly advise you to READ the text bellow the marked one, that says ''WARNING''
*#8999*8378# -For menu debug all
#*7728# -For full master reset ,that will reset ALL,
and I mean ''ALL'' things on your phone,totaly clean,
and rdy to be filled up again with memory
*2767*3855# -For full EEPROM reset,which is most wanted right now,
and resets all types of locks/security passwords
WARNING!!!
BEFORE YOU DO IT, make sure you did all the things i prev wrote.This will delete some of the settings on the phone,changing the phone themes to default,phone menu appearance,sometimes phone/call/message ring tones,on some phones messages(and MMS),return all internet settings to default,and possibly deleting your network call center number,and INCLUDING the very same things you could not open,'cause it was password protected.So, if you cannot save these things to another memory spot than your phone memory, I advise you NOT TO make these resets,'cause you WILL lose all you needed to unlock in the first place.
If you did all things right,and followed my instructions, than this should be a piece of cake for you,and should do just like I told you.However, I you still have problems with this matter,and still need help,you can contact me via simple E-mail
anemiandEh@yahoo.com
I apriciate your time taken to read this,as it was suposed to be shared by all who have similar dificulties.Thank you
