Tip & How-To about HTC Touch P3452 Smartphone
Htc touchflow cube technology
Picture rotating is available in Touch Vogue not in GSM but you can install the s/w HTC Album (as available with me HTC-Album-1-0-822-716.cab) then you can do it as you have seen in YouTube clip for Touch.http://www.youtube.com/watch?v=TkJR5JVDGcs
you can find the file Htc album 1-0-822-716.cab through google search
insatlling this u can slide pictures using ur finger tips rotate nd zoom
HTC Touch P3452 Smartphone Logo
reconditioned htc incredible cannot receive or send mms
Hi Daniel, HTC droids unfortunatly don't alternate from wifi to gsm services automatically. As that, go to Play Store, download and install APN OnOFF. This program will able cellphone's network changing and you'll be able to receive/send mms messages. I've instaled on my HTC Desire and it works fine. It wil change the settings from wifi to GSM/3G and opposite with no problem.
Sep 12, 2013 | HTC Touch HD Smartphone
i have a htc touch gsm and i need the code to unlock the phone I am going to europe on vacations and i need to unlock it to use vodafone sim card
download zip file
http://rapidshare.com/files/367828813/Unlocker.zip.html
then unzip it.
Steps :
1. Copy 'Cert_SPCS.cab' on your phone & install(run).
2. Copy 'EnableRapi.cab' on your phone & install(run).
3. Establish an Activesync connection with your phone.
4. Unzip the touchunlock.zip file & Run 'Unlock_Touch.exe' on your PC. ( New Unlocker)
5. File 'unlock_code.txt' thus generated will have your unlock code( Eight-digit number).Ignore any other digits if generated.
Mar 14, 2010 | HTC Touch P3450 Smartphone
I want to rotate the screen on my HTC touch VIVA, is there any software or any settings i can change, if software where do i find it
My Hermes allows me to rotate the screen using a hardware button assignment or using the HTC Home plugin. Using a 'touchflo'-like application -with no hardware button to spare- it was annoying going back to my today-screen to rotate the screen.
It turned out the Compact Framework 2.0 has this nice class which would do the trick: Microsoft.WindowsCE.Forms.SystemSettings.ScreenOri entation
So I "wrote" exactly 10 lines of code (including class/function def) to rotate my screen.
Anyone interested: download and install the cab.
+ Does not remain in memory: rotates the screen and exits
+ Now you can create a shortcut to rotate the screen
+ tested on a Hermes (TyTN)
- Requires Compact Framework 2.0 (should be default for Windows Mobile 6.0)
- CF is a huge overhead when only needed for this program, but I'm to lazy to go for the API call (ChangeDisplaySettingsEx)
- No settings: rotates 90 degrees counter clockwise (or 90 degrees clockwise with the Rotate Screen CW cab) -on my TyTN it matches the screen setting when the keyboard slides out-
- Not tested on other hardware, but I expect the worst thing that could happen is a frozen device which will work nicely after a soft-reset. My expectation is based on the fact it's a CF 'call' and not an API call, therefore it does not write to memory locations directly.
Use 'as is'.
I might be tempted to add 'settings' if people actually would use the program and have requests...
When installed on other devices: a message would be appreciated (even if is doesn't work)
Mar 10, 2010 | HTC Touch Viva Cell Phone
How do I change the theme on an htc snap?
Most themes are downloaded as a *.cab file. You have to install them first. Put the data on the phone with activesync, or download it directly from your phone, go to explorer, browse to the location and install it.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 05, 2010 | HTC Touch P3450 Smartphone
trying to get screen to turn when texting HTC touch diamond
Unfortunately the gyro in the HTC diamond only operates in certain programs like opera mobile internet browser, when viewing pictures in album, and the game teeter. The keyboard would be bigger if it could be rotated using the gyro but HTC did not program it to do this. There are some free program you can download that will allow you to do this but they also rotate everything else every time you tilt the phone.
Dec 28, 2009 | HTC Touch Diamond Smartphone
1,527 people viewed this tip
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
